Btw, I remember your conversation with Lloyd about oil, and the facts he presented about Vic's containing multiple (3?) types of bearings, while fully synthetic oil worked best with a single type bearing.
Correct me if I am wrong, but your reply to his facts, was anecdotally based on your own bike, while he was trying to make general recommendations for ALL his customers.
Btw, I used full synth in every vehicle I have owned since they started making it readily available, but I find that irrelevant. Especially since my bike shed has no; Harleys, Fords, Dodges, toyotas, Goldwings, or fleet trucks.
The discussion with Mr Greer, you are correct in what he had said that in his experience this Synthetic stuff kills a Vic motor due to the Ball bearings sliding and not rolling in their races. Now more to the story, I use oil analysis to determine the health of my engines. Proper oil analysis will show particulate matter and can be traced to components breaking down ( I think we can agree on this point). My analysis shows no abnormal wear and I am using full synthetic.
Hummm how can that be if Mr Greer states that oils such as AMSOIL are "Too slippery" and cause the ball bearing not to roll and fail.
I was told that my bike would be in the shop at 60k miles due to bad bearings as a result of the oil I use. I must be an exception or impending doom is just around the corner because I have 60k mile on my bike and show no hints of impending doom.
I do not dispute Lloyds finding on bearing failures, I just can't connect the use of a full synthetic oil to the root cause for the failure. So I correct my statement that the conversation tilts toward abuse, Comparing what I have in oil analysis on my bike, and what was told to me from Mr Greer, the two do not align. Therefor the only conclusions I can draw from the conversation are these:
1) The Bearings that Ma Vic are using are inherently flawed and are breaking down after a certain number of hours ( Hours equating to miles driven) leading the builders to the oil conclusion. I would like to see the evidence of the failed parts.
2) The operator of the bike is abusive in nature and stresses the components to the point of failure. The 106 engine was design to a spec, and lives well within that spec. is it well enough? I think we both know that answer as we have both modified the machines we ride and are quite happy with the way they work.
Time will tell, I will be quite happy to buy you a case or crate of your favorite beverage if I am found blown up on the side of the road over the next few weeks as I will have greatly surpassed the mythical 60K mark with Synthetic oil internal to my ride.
