Notaharley, when I went to the magnumtuning website and looked at the spark plug you mentioned, I immediately Flashed-back to the 1970's when a company called "TORQUEMASTER" was selling plugs that looked very similiar to the ones you were talking about,
So I googled Torquemaster spark plugs just to see if they were still around and sure enough they are, But their website is called
www.extremespark.com check it out they've really got a SUPERIOR plug to offer, I didnt know they were still around because Mauri Lindsey (the Inventor) said to me back then that the torquemaster plugs would'nt work in computerized iginition systems, so I figured they went the way of the the dinosaurs, and were limited to only "OLD-STYLED" iginition systems (points &plugs-magneto-etc), well I guess they found a way to make'm work with modern systems. this much I can tell you from REAL-WORLD experence
I had a 1973 chevy van with a 307c.i. v-8 truck engine w/ a 3 speed manual tranny (3-on the tree), I was a auto shop teachers aide at the time and REALLY into cars, my chevy van was averaging 11 mpg, and that was with a super tune using the "SUN-SCOPE engine dyno set-up at the time, I dont even know if there made any more but it was State-of the-art back then, after reading an article in one of the car mags about the torquemaster plugs, I decided to go to their shop and see if it was "FOR-REAL", after talking with mauri and seeing his DEMO I decided to Try it out, he reshaped the centrificial advance lobes (because the plugs caused a faster burn-so to maximumize combustion) on my distributor and put the plugs in, that was it RESULTS, my van was faster(seat of the pants dyno) BUT my mileage went to averaging14 mpg, I pulled out a couple of plugs after 50,000 miles and there was no carbon any where on the plug, I was sold. one last thing of interest, When mauri DEMO'ED the plugs he did 2 things that were amazing 1-he took one one the torquemaster plugs and dipped it in axel grease so the entire electrode was covered-then he put the plug in one of those old champion spark plug boxes you'de see at auto parts stores where to could press the button and watch the sparkthatyour plugs would make to see what shape they were in, the torquemaster plug burned off all the axel grease, that was pretty cool. Then 2-he took the same plug and dipping it in axel grease again, and put it in a honda 305 scrambler motorcycle (kick-start mind you) and removed the other plug, so only the torquemaster was in the honda, and started kick starting it it fired right up, although it ran rough because it only had one plug in the engine, BTW I dont work for or own stock in his company, like I said earlier, I didnt even know they were still around, their website has some dyno videos that are informative, just my 2cents.
