Not to start a big oil thing here I know how this gets. But I am curious if anyone is using Mobil 1 v-twin motor oil and what you think of it ?
Absolutely good MC oil. Has been in my son’s VTX since 2004. He tried to go cheap and use Honda Dino oil ( still good oil ) but rode 1 day and dumped it. Back in went the Mobil 1. 4t 10/40 I believe shifts like butter and that bike has a clutch in it that Victory should have had.Very high quality, only udes that on my Vrod Muscle that was tuned![]()
Unfortunately, I won’t be using it for a little while as both bikes just had an oil change recently. One is up to 1500 miles and the other only up to 500 miles since the oil change. Was hoping you could shed some light on your experience with the 2050 ultra one plus?Let us know how it goes Slick. I run the 20w50 semi-syn as well.
Picked mine up yesterday. Delivery was to the date and the packaging just fine. Less than $30 an oil change with real motorcycle oil and not diesel truck oil. The fact that it is only Jaso ma2 and not ma means it should grab and hold pretty.I will also be switching to the Ultra 1 plus at my next change. Tractor Supply is one mile from me, shipped free to the store.
Have had 2 oil changes with it so far and no complaints whatsoever. I’m one of those crazy nuts that does “by the book”,meaning a full 5k between changes. No indication of slip or breakdown. The 50w helps in the heat we get down here and the top end is quieter.Unfortunately, I won’t be using it for a little while as both bikes just had an oil change recently. One is up to 1500 miles and the other only up to 500 miles since the oil change. Was hoping you could shed some light on your experience with the 2050 ultra one plus?
do you mean the switch attached to the clutch lever?I'm not familiar with Vics but the Indians need the gear indicator switch cleaned every 10,000 miles (recommended). The display can show just like you indicated. Just had mine done.
No, I familiar with what you're referring to. Gear indicator position switch. They had a recall on it a few years back. Here's a little background on that...do you mean the switch attached to the clutch lever?
And, Rotella T5 is also rated! View attachment 658262
Well anything is possible. I actually spoke with mobil yesterday and the 15 W 50 4T I come to find out it’s not even available in the United States. So I believe I’m going to give the 20 W 50 V-Twin a go. I spoke with another rider on an Indian forum. his bike has 78,000 on a 16 Chieftain using Mobil 1 since his 1st change at 500 break in. No issues no clutch slippage. I’m gonna give it a go and see how my bike runs on it as they say nothing ventured nothing gained. Slightest bit of clutch slippage I’ll dump itI might be wrong, but I used Mobile 1 Racing 4T in my Victory and thought it ran hotter than any other oil I used.
Mike , why not try the 20/50 ultra plus full synthetic ? $5.99 a bottle and your not wasting money if you don’t like it.Well anything is possible. I actually spoke with mobil yesterday and the 15 W 50 4T I come to find out it’s not even available in the United States. So I believe I’m going to give the 20 W 50 V-Twin a go. I spoke with another rider on an Indian forum. his bike has 78,000 on a 16 Chieftain using Mobil 1 since his 1st change at 500 break in. No issues no clutch slippage. I’m gonna give it a go and see how my bike runs on it as they say nothing ventured nothing gained. Slightest bit of clutch slippage I’ll dump it
I’ve actually been kicking that around also Vic definitely cheap enough. The Mobil’s running $11 which is for a high quality oil tolerable.. I researched it and it doesn’t have as a good a rating for heat and running hard for engine protection like Mobil 1 tho. You know what a fan Ive been on Redline and after some serious research this damn Mobil one matches up closest across the boardMike , why not try the 20/50 ultra plus full synthetic ? $5.99 a bottle and your not wasting money if you don’t like it.
I run Redline in my SRT8. Both tranny and rear end. The motor gets Schaeffer premium synthetic. Amazing oil. Can you post your findings on the oil you researched. I’m interested in stats.I’ve actually been kicking that around also Vic definitely cheap enough. The Mobil’s running $11 which is for a high quality oil tolerable.. I researched it and it doesn’t have as a good a rating for heat and running hard for engine protection like Mobil 1 tho. You know what a fan Ive been on Redline and after some serious research this damn Mobil one matches up closest across the board
Schaeffer is great oil. I wish they would make oil for Indians and Vics with just the JASO MA2 designationI run Redline in my SRT8. Both tranny and rear end. The motor gets Schaeffer premium synthetic. Amazing oil. Can you post your findings on the oil you researched. I’m interested in stats.
no stats technically a couple of articles I read.i looked up Mobil 1 vs Redline it had some good info on them. Mobil 1 heat viscosity break down pretty damn close to Redline surprisingly. And this here I came across.I run Redline in my SRT8. Both tranny and rear end. The motor gets Schaeffer premium synthetic. Amazing oil. Can you post your findings on the oil you researched. I’m interested in stats.
The recommendation is full synthetic for the powerplus, scout, FTR, and some thunderstroke motors. Semi-Syn for other thunderstroke motors.Do the Indians take full syn? For my Vision, running the U1P 20w50 semi-syn.
All due respect ….. this says nothing. Pros are what’s on the bottle. They are bothe good oils doing pretty much the same thing. Cons are purely speculation. I’ve not tried UP1 although I own 9 bottles of 20/50 semi synthetic so I’m in the dark about its performance other than the good things said here by the good people that use it. My take on it and my future oil changes are as such …….no stats technically a couple of articles I read.i looked up Mobil 1 vs Redline it had some good info on them. Mobil 1 heat viscosity break down pretty damn close to Redline surprisingly. And this here I came across. View attachment 658388 View attachment 658388
