1 - 12 of 12 Posts
I'd put a small clamp on that hose to start with. Can you dry it off and tell exactly where it's leaking from on the fitting? There's three potential sources there.
@Jybrd1 Being that yours is new you should take it to a dealer and have them replace the line assembly. Otherwise you could just put a mini hose clamp on it. Open the clamp and put it around the hose then screw it back together. Don`t try to take the hose apart to put the clamp on.
@Jybrd1 Don`t try to take the hose apart to put the clamp on.
I assume it doesn't go well? Im trying to figure out a way to get it to my dealer. I don't want to drive with the steady drip of gas on my engine. Im doing some searching online and I probably broke the connector with the green tabs when putting it back on somehow.
1 - 12 of 12 Posts
