V92 Touring Cruiser rear wheel
1.9K views 5 replies 2 participants last post by  linerider
#1 ·
I broke the hub on my rear wheel and I can't find a wheel that says specifically its for the Touring Cruiser. Will a classic cruiser or cruiser wheel work
#2 · (Edited)
Rylan at the Vic Shop sells an adapter kit so you can use later model wheels from a KP or Vegas, etc. I actually found billet KP wheels. The later model wheels use larger bearings that don't fail like the TC wheel bearings. I use an 18" tubeless Avon radial tire. Really improved the handling. The kit comes with spacers, a machined rear brake bracket, etc. But you have to come up with later model wheels and rotors.
Saying all that, here's a link.
02 VICTORY DELUXE TOURING CRUISER REAR DUNLOP WHEEL TIRE PACKAGE 160/80B16M/C80H
Items for sale by motoplaneparts | eBay
Looked up the part number for the cast wheel. Looks like it goes from 2001 on up including the TC's.
victory 5132635
#4 · (Edited)
If you use billet wheels, the front wheel has hubs that bolt to the wheel. The rotors attach to those hubs. I was lucky enough to find these brand new at the time off a Ness KP. Also found the hubs and a rear pulley to match. Got a pretty good deal. The new wheels have a 6 bolt rotor pattern, so you have to find new rotors. Rylan has a kit you use that spaces the calipers to the rotors. Just have to run the front rotors backwards. Or, you can the hubs machined down a little to match the caliper spacing. You can use either a 16" or 18" rear wheel. The tire sizes come out to be the same diameter. I think it's a 180/55/R18 for the rear. I was just patient and checked eBay quite a bit.
victory wheel | eBay
I just checked the salvage place I got a motor from. Here is what you want for front hubs.
05 Victory Vegas Hammer Front Wheel Hubs
If you like the look, pretty darn sure cross bike or vision wheels would work with rylan's kit too. Still would have to come up with rotors. They have a 16" rear wheel and it takes a GL1800 rear tire. I use an Avon 180/60/R16 on the xct.
#6 ·
Thanks for the compliment on the TC. Love that bike, so much fun to ride. The Avon radials really helped the handling. The hubs mentioned work on billet wheels only. The stock KP wheels are cast all in one piece. Hope all goes well!
