Vgreid said:
I didn't do anything about it. It is so small that it really is not noticeable.
x2
You hardly notice it. I peeled off the little edge protector strips too since they're no longer needed. It cleans up the top edge of the outer fairing nicely. If you're
really tall, you might be able to see into the gap while riding, but everything in there is blackso it is not really a big deal. Would probably look worse if you tried to fill the gap.
As for the OEM vs. 11" MadStad shield. I've ridden witheach of themfor a few months now. Height / wind protection is nearly identical, the MadStad shield just looks nicer as it wasn't designed to be tucked into the gap. One difference I did notice though... Iwas ableto ride with the OEM adjusted all the way down and all the way forward and it was fine. Due to the MadStad matching the lines of the fairing so well, if you adjust it all the way down and all the way forward, the air gap between the shield and the outer fairing becomes very small, maybe about 1/8-1/4". At speeds over about 70mph or so it did not seem to be letting enough air in behind the shield which was causing some turbulence. I think the jagged bottom edge of the OEM shield was allowing for more airflow so this was not an issue. There's not really a reason to ride with it in that position, but I thought it was worth mentioning in case someone was having buffeting issues with it set like that.
