1 - 9 of 9 Posts
No way 120 to the rear wheel with stage 1.
+1
If you want more power your going to have to go with a two into one exhaust, Cams, PMRT and a VFC!III.
That will get you up into the 110 - 115 range.
Check out LLoydz dyno graphs
http://www.hardonhorsepower.com/
texhammer said:
The swept were on it when I got it.
I'm just curious about what I have before I start adding on.
David:
Check you manual. In the VIN of you bike is the stock hsp rating. With the 100's I believe it is around 85 hsp.
Going Stage 1(air filter, fuel map) w/ Slip-On's will jump a 100 ci up to around 92 hsp.
The one thing I have found out since my dyno fiasco and talking to VERY qualified Vic mechanics is the new fuel maps(since '08) will set your bike to run rich. ie more hsp, less mpg.
The map in mine is a '05 thus my bike was running lean(less hsp, great mpg).
I thought the '09 106's were coming out around 87 to 90 hsp, but just a guess there.
I have posted these two many times, but once again:
Jeremy @ Surdyke Victory or
KevinX on www.thevmc.com
They should be able to answer most all your questions.
Or you can call my guys at NorthwaySports.com here in Minn. They can answer your questions also.
Good luck!
Roger
1 - 9 of 9 Posts
