1 - 4 of 14 Posts
Get a repair kit and remember the drain plug only needs 15 foot pounds of toruqe. To many people tighten a drain plug like a gorilla because they think the drain plug might loosen andthey will loose their oil while riding. It is not going to happen. The drian plug is not a stressed bolt holding parts on.
Give it 15 foot pounds Vasili, only 15 foot pounds please.
I have had oil change shops tighten the drain plug so tight I almost could not get them undone. I no longer let shops change my oil with the exception of my Mazda that has an oil change contract but when that contract runs out I will be the one changing the oil in it as well. I just hope the shop does not screw up the drain plug and threads on it first.
Nessie044 said:
I'm with RedVic. Do it right and repair your scoot, then you never have to worry about it. Here's your huckleberry:
http://www.arizonavictory.com/eshop...ry.com/eshopprod_cat_2302-61027_product_741462.Oil_Drain_Plug_Repair_Insert.htm
If you don't want to do it yourself, I can't imagine your dealer or other motorcycle shop charging you any more than an hour labor to do the repair.
That is the route I would go. That way it is done right and you don't have to worry about any more.
1stVictory said:
Question about making sure it won't leak at the repair - would using white teflon pipe tape on the threads of the repair bolt be a good idea to ensure a good oil tight seal? I imagine it may be slightly tapered. Having asked this, I can see the possibility of the drain bolt bringing out the repair bolt with it!
1 - 4 of 14 Posts
