I have tried searching and researching the hell out of cams for the freedom 106 and ended up just being confused and undecided.
I have a 2011 hammer 8 ball. I currently have hacker ripper exhaust. I want a cam, torque tubes intake, and I'm going to use the Maximus tuner.
Can someone with experience or who has researched the hell out of these cams please clarify the difference? And make a recommendation?
Riding style? I like to take off like a bat out of hell once in awhile. I like how it spins the fat tire a little bit and then takes off, but I feel like where the bike is lacking power is above 3000 rpm.
And if you are cruising and 30, 40, or 50 and downshift, crack the throttle, it just doesn't pull hard enough for me.
I also like to drag race and will be taking it to the track. So quarter mile times are important.
There's the VM1 cams, the LSC 505, and the Andrews V413.
I'm leaning away from the VM1 because my understanding at this point is they are for more low end grunt, which is fun but not where the bike needs the power.
If you experienced guys out there can help clear up the difference on these cams and help me make a decision, I would appreciate it.
Thanks in advance.
Thanks in advance.
