Just wanted to ask can you remove the Vision's front fender without removing the front wheel?? Looks possible if I remove the brake calipers.. My bike is used, and I see that one side of the fender has cracked and repaired by p.o. But now the rear mounts have cracks and I want to pull it off and correct the issue.
Other question is how do you get the trunk lid inner and out panels apart? Do I just need to pull all of those Allen heads from the inner panel? I am going to add some LED strips for turn signals, and need to get access to run my wiring...
Hey thanks for any guidance you are able to provide......!
