I have an 07 Kingpin tour, that I replace the clutch cable with a hydraulic clutch. And as some of you may know that is the black triangular master cylinder for that. So to make it match I bought an 08 brake master cylinder but now I need to make the wiring fit the 08 switch.
Has anyone done this before? Is there a connector that I can splice in? Or should I just use regular shrouded slip clips?
