1 - 2 of 2 Posts
Mr. Talisman
Discussion starter · #1 ·
Too many added Turn signals to 2015 Vic CC Tour?
3 years ago I added Hog werks LED lights to my engine guards. They have worked flawlessly being white while running and blinking amber when using turn signals.
Yesterday I added rear turn signals that attach to my license plate. The right side is working fine but when I put the left turn signals on they blink a few times and then all left turn signals shut off. The front and rear OEM left turn signals and the aftermarket lets turn signals too. If I turn the key off and then start the bike up again only the left turn signals blink a few times and then shut off.
When I swapped the aftermarket license plate turn signals the right side turn signals blinked a few times and then shut all the right side turn signals off. The left side after market turn signal worked fine.
?Do I have to find a heavy duty flasher or relay when adding this many turn signals? Even when they are LED?
What is happening?
Tim in Bloomington
If I read your post correctly, The one that's shutting off on the license plate is faulty. That's why when you swapped the sides, the issue swapped to the opposite side. Doesn't seem to be anything wrong on the bike. Can you return them for a refund or exchange?
  • Agree
Reactions: jmstang302
1 - 2 of 2 Posts
