1 - 4 of 14 Posts
WickedWebby
Discussion starter · #1 ·
Hey Everybody,
I know there has been talk about the newer Victory's being rpm restricted in 5th and 6th gears resulting in the 120 mph cut out/restriction. Yes, it is true.. Thanks to KevinX for squaring me away with regards to this being rpm related with 5th and 6th gear and not indicated MPH related. As I initially was hoping. I have unrestricted my share of bikes over the years (usually for the 186 mph restriction). So I was very interested in this. An older Vision service manual is all it took to get it figured out. Thus, it works for the Xbikes too.
(DISCLAIMER):
If you do this very inexpensive modification, Do it at you own risk! If you are the type of person that rides very fast... Please do not do it! Know that if you are riding at high speeds you could face GRAVE consequences. Also, DO NOT try to hit your toggle switch "on the fly" while your riding fast. This could cause a unsafe situation where you could possibly crash.
(PREACHING):
Please understand the legal problems you could face if you were caught riding at high speeds. Also, remember the dangers involved with these type of speeds. Too yourself and other people. If your only purpose to un-restricting your bike is to ride at high speeds... Please do not do this modification.. The 120 mph rpm restriction is fast enough! I accept no responsibility for anyones own stupid behavior. I only accept responsibility for my own stupid behavior. Which is enough for me already!
(Enough of that):
Anyways... Your gear box has a 2 wire white connector with a Black/Yellow wire (+) and a brown wire (-). This connector (at least on the Xbikes) is located below the rear cylinder exhaust header. Near where the black wire from the 02 sensor goes. You can wire tap into this Black/Yellow wire (no need to cut it) or just unhook the connector and securely sandwich in an appropriate wire between where the Black/Yellow wire connects together. You can decide where you want your toggle switch to be located. On the handle bars or anywhere else you might figure is easy to reach. Take this added wire to the (+) Black/Yellow wire of the gear sensor and attach it to your toggle switch. Now, all you have to do is run the second wire off of your toggle switch and attach/solder that to a 10K Ohm 1/4-Watt Resistor. You can find these at any electronics store including Radio Shack. Secure the resistor to a good ground screw on your frame of anywhere else that conducts a good ground. Do not attach it to the negative brown wire from the gear sensor.
(How it works):
Your gear sensor is a very low tech system. The ground is used for neutral detection. The other gears are detected by preset Ohms coming from the positive wire of the sensor. The lower gears are preset for specific lower ohms and the ohms step their way up as you go into higher gears. The switch, with this amount of an added resistor (when switched on and added to the circuit) adds resistance to the higher gear ohms presets (reducing them) and tricks your bike into thinking it is in 4th gear. So.. Turn the switch on and your gear indicator (on a XC for example) will indicate your in 4th gear even when you are in 5th and 6th gear..Your bike will think it is in the lower gear too. Thus, now you could (in theory) actually red line 5th and 6th gears at the same rpm that 4th gear goes to. On a closed race course and if you had enough power. Switch the toggle off (kill the resistor circuit) and your gear indicator will work as usual.
I will attach a Radio Shack link for the resistor, a photo, and a switch diagram.
Wicked Webby
http://www.radioshack.com/product/index.jsp?productId=2062347&filte...
Discussion starter · #3 ·
mjw930 said:
Webby,
Great DIY and I just want to expand upon your disclaimer so everyone understands what "could" happen if you are fool enough to play around with the toggle switch at speed.
Imagine you are running at 135 mph in 5th or 6th (not sure if the motor can pull to that speed in 6th) but you've faked out the ECM to think you are in 4th. You disengage the toggle and now the ECM see's you are in 5th/6th and bangs on the rev limiter. Your rear wheel will now LOCK UP under engine breaking AT 135 MPH!!!!!!
I just felt the need to point that out because you know there's some fool out there who will feel the need to hit that switch and we don't want to have to say "I Told You So" to his widow.
mjw930,
Good additional point. Isuspect that thebike would just shut down the power. Just like it does around the 120 mph mark..I don't think the ECU could lock up the tire. Even if the bike stopped running.. It would be in a high gear and would justrespond like a down shift. Regardless, at that kind of speed, having a sudden power loss could THROW you for a loop.. LITERALLY!
Thanks,
WW
Discussion starter · #8 ·
Radioteacher,
Thanks for your response. Glad you shared it. I hope some of the folks on the Vision-Riders.com will benefit from this. As you know.. It will work the same for
the Vision.
WW
Discussion starter · #12 ·
Monkey666,
All about disclaiming... Somefolks might want to test their (in theory without wind resistance) top speed on the dyno. For that WOT top speed tuning.
I am just getting ready for Lloydz cams along with my other goodies...I do want to see what my XC can do. Someday.. Maybe on a closed course or something.
WW
1 - 4 of 14 Posts
