1 - 8 of 8 Posts
Jp.
Discussion starter · #1 ·
2015 Hammer--
I have about 370 miles on her and the clutch lever has started rattling pretty good. Is this normal and can it be fixed at the 500 mile checkup?
Take the lever off and lube the pivot point with some grease. It wont make it completely quiet but it helps. Yes it is normal and a good sign that the cable is adjusted properly.
Reactions: Jp.
Agree with the previous answer. My Vegas has 2000 miles on it and I noticed the same thing. Took it apart and re-lubed everything. Didn't completely go away but it helped with the noise. It's tolerable now.
Reactions: Jp.
Discussion starter · #4 ·
Thanks so much guy's
Any particular lube recommended.
You sure really go to You Tube and watch a Video on Clutch a Cable adjustment from the Victory Rep for Police Bikes. Great info and there are others, some of the guys will list...
Victory Clutch adjustment and cable maintenance - YouTube
â–¶ 6:07
www.youtube.com/watch?v=k_iS2OutTxw
Apr 15, 2013 - Uploaded by Victory PoliceMotorcycles
Clutch Cable adjustment and maintenance are demonstrated on a Victory Cross Country ...
I use Moly Fortified Grease but any type of nice slick chassis or bearing grease will work for the barrel ends as well as the pivot bushings. Whatever you do, do not lube the cable...just the barrel ends.
Reactions: Jp. and Flyboy
1 - 8 of 8 Posts
