I purchased a plug and play LED headlight kit. When I went to install it I realized that both connectors for high beam and low beam are the same yet have different fasteners. Hello beam fastener does not connect as easily. I had to modify it. The gray part of the fastener does not fit between the vents on the housing. It is designed just as the high beam fasteners location on the housing. The problem that I am having is no matter how I hook it up the low beam does not work. There is only power to it when you switch to high beams. So you only have one or the other. You cannot have high beam and switch to low beam because then you have no headlight. I don't know how else to explain this issue. Has anyone else run across this issue? Can anyone help?
