Heated Seat question
5.4K views 7 replies 8 participants last post by  Chelnick
Question, when u put the passenger switch up (high heat), is it giving you the high heat or low heat setting? Is the front switch controlling the passenger seat and is up giving u high heat? Because it just might be the two switches need to be backed out and reinstalled properly. There are 2 screws under the seat to access the rear of the switches. Good luck
