Was wondering if anybody changed out their headlight or bulb to something different? Looking for something brighter. Maybe HID?
Cruzie27, have you called Kyle and asked him about the PCV for your 2016? He may have a solution for you! Also, if he does, he will be at SM City Motorsports the weekend of the 18th for a Cam Party and Dynotuning. He may be able to solve your problems and install your TTs, timing wheel, and cams at the same time he tunes your bike. It's a bit of a ride but not too much more then going to RI.
The light housings are off of a 2014 model and in addition to the housings,. Bezel,. Rounded washer, & other small hardware you need to make sure you get the "nest" or "pursuit light nests". This part has the little cutouts to hold your lights level, and a notch to keep it in place in the housing, which is all secured by the bezel. If you do not get that unassuming little part for each housing the vibration from operating the motorcycle will make the lights turn / spin in the housings. This damages the lens of the light,.... Learned that the hard way.No worries, Ill find them, now that I know what they are, thx
