1 - 10 of 10 Posts
Melaza
Discussion starter · #1 ·
After weeks of dealing with this issue, bike Will NOt go into 1st gear. At first it was giving me a hard time, now it just wont go into first at all....time for Stealership to step in..Fail!
Is the bike under warranty? If not, I'd find someone else to take the bike to instead of a dealer (unless its a good one). Where are you located?
Check out Kyle Crandel. He's in Westerly, RI. KMC Powersports. He's one of the top victory mechanics. He'll fix you up without all the BS. He might be able to give you advice for fixing it yourself (might be simple).
Reactions: Melaza
Loose and worn out shifter splines? The shaft should be good as it's really hard metal.
1 - 10 of 10 Posts
