Crossroads adjustments
2K views 7 replies 6 participants last post by  Sgtpete55
Did SRVT tell you they had to change the brake line? If so they're wrong; I put XC bars on my XR and used the factory cables/lines. I had to route the front brake line and the cruise wires under the top tree. this gave me enough slack that I still have about 1/2" droop in the cables/lines. The longer line will come in handy if you get pullback risers. The factory ones would not make it much farther than the extra 3" my set-up used.
