HI all. Went to start my 09 KP and something strange happened. Usaul starting procedure..hit the start button and wtf...the lights go out and no start. It did have a buzzing noise which was located to be the primary light relay.
What I did...checked voltage of batt. Good batt. Cleaned battery terminals. Checked and had same buzzing from the 15 amp primary light relay. Bummer.
Did I blow the primary lights repay? Could I switch the secondary with the primary to check? I noticed both have same numbers.
If I have to replace, should I do the primary and secondary?
Appreciate any help.
