Gentlemen,
I know this is an old post....but I'm about to do a clutch job using the Barnett/ Lloydz setup.
How did you guys finial make out with your instalation?
HC did you ever design that part you were talking about?
Any additional comments/suggestions are welcome .
Thanks
Mine is working out great. Make no mistake, it's a man clutch; more solid and harder to pull than the stocker.
I don't know the status of whether or not H_C ever got that part made. I ordered mine from Victory. If you end up ordering, be sure to get one for an older cross bike. I think I ordered one for a 2010, but it's in one of the earlier posts. It's called a clutch lifter assembly (CLA) and is on page 9.13 of the service manual if you have one. If you don't have one, get one. Now for the fun part...that new (older) CLA is stronger and will withstand the force, but it is too long to use with the Lloyd'z support plate. Because the plate is thicker, the CLA will extend and hit the back side of the plate when you pull in the clutch lever. The fix is to grind it down. I know, I know, I was skeptical too, but this tip came from Kyle at KMC Motorsports and it is necessary if you want to use the Lloyd'z support plate. I simply installed the CLA, laid the bike over on its right side, put a fire proof welding cloth around everything and took a pneumatic grinder to the CLA until it was just right. Man, I was nervous, but it worked.
One of the best tips I got was from VOG member Squatch. Go to the local hardware store and buy 4 or 5 extra primary cover screws. Cut the heads off of them and use them as guides when you are putting your cover back on. The stator makes it a ***** to guide the cover on and keep the gasket in place all at the same time, but the guide screws help a lot.
This is not a project for the faint of heart and I had a lot of help from H_C, Squatch, KeithGrey and over the phone from Kyle. I felt good when it was done as it was my most in-depth project yet, but the help that I had is what made it a success.
Get a manual, take your time and get some help if need be.
You'll need a spring compressor tool. I have one that KeithGrey had made for me and I'm more than happy to loan it to you if you need it. Not sure where you're located, but shipping should not take all that long. P.S., Victory won't sell you one and neither will the manufacturer. No matter, the one I have is better anyway.
