1 - 14 of 30 Posts
Discussion starter · #11 ·
Thanks for the info, hertz 6.5 or 5.25? I watched a video of a guy pooring water into the kicker 6x9...held it like a bowl. SOLD! There may be better sounding lid speakers out there but if they leak what is the point?!
Discussion starter · #15 ·
Gotcha. So was it worth the cash and time? My X1 has alpine fronts and is stupid loud, but the clarity at speed leaves much to be desired. The highs will make your ears bleed but the mids and especially the lowes are sad.
Discussion starter · #19 ·
Check. I like the install combo you used and I think I will reference this when it it time to complete the audio right. For now I may just get the 300w amp and power the fronts with it. Also will fill the box with polyfill and dynamat the outside of the box. Cheapish upgrade to hold me over for now. I think HMD has HW300w amps for $300... Not bad I think.
Discussion starter · #20 ·
In your experience do you think I would be able to piggyback off the above mentioned system without trouble if in the future I had the funds to do your full set up?
Discussion starter · #23 ·
I think X-1 is 2X 100W amps, split 4 ways for 50W max to each corner. The alpines are better than stock hands down, and I am told the stock amp won't bring out their best. That is my logic for starting with one HW amp, then getting the rest of the kit when I can. Burnable money on hand is also a big factor.
Discussion starter · #25 ·
You have given more than enough knowledge tonight. I will keep asking questions though if you are willing to still answer them. Did you put dynamat in your bags or fairing to help your sound?
1 - 14 of 30 Posts
