Well I finally installed the Zumo 660 on my Vision today. Install was a breeze. It took a couple of hours just due to the fact of checking and re-checking and re-checking before actually drilling holes. I went with the mounting bracket and wiring harness from Victory. Pricey but well worth it in that I had to do no modifications. Works well and I get directions through the speakers. It's is nice to know that I did it on my own instead of paying the $90.00 and hour to have it installed by the dealer.
Blank Canvas
This is the underside of the console. You have to seperate these two pieces to see the GPS holes. (directions don't tell you that)
This is the connector that is on the right side between the frame and right gas tank
The nervous part was drilling these holes but the mount holes are set up for you. The hole for the wiring is not but pretty easy to figure. The directions for the wiring hole says use a 16mm drill bit which I could not find so use a 5/8" bit. It is just a smidge smaller than 16mm and worked fine.
Once all the holes were drilled the mount and the harness fit perfectly.
The finished product.
Blank Canvas
