Might try Leaders RPM. They had a lot of old Victory stock they were selling cheap.as it says trying to track down a toe heel shifter for my 08
Try hitting all the pivot points with your favorite spray lube.Vic does the one send the link for does that weird peg pivot or what I had toe heel shifter on my roadstar and loved it. Also got very used to it I sometimes notice it's hard to shift the vision if I don't hit it at the right spot rpm and the heel might give me a little more hit for it
I know what you mean. The heel shifter never seems to miss.Vic does the one send the link for does that weird peg pivot or what I had toe heel shifter on my roadstar and loved it. Also got very used to it I sometimes notice it's hard to shift the vision if I don't hit it at the right spot rpm and the heel might give me a little more hit for it
Bushings will not work on early model bikes. Has tobe 2011 or newerTry hitting all the pivot points with your favorite spray lube.
It may also be time to replace the pivot bushings.
Look at this on eBay For Victory Cross Road Vision Magnum 4x Shift Brake Lever Bushings Pedal Shifter | eBay
Okay then, if I can't make the bushings work on mine I'll be getting the heel shifter too.Bushings will not work on early model bikes. Has tobe 2011 or newer
That's a killer deal - I ordered one. Thanks for the find.
Yep. I picked one up a good while back. I don't use it often but it's nice to have it for when I wish to. Cheap enough that I still get my money worth from it.That's a killer deal - I ordered one. Thanks for the find.
I have a new one in the garage, one piece with the six sided hole. $80 lower 48 e mail me for pictures [email protected]
I think they listed and many were sold for $189. The $60 is a blowout price.$80?
But in the link it's only $59.98 shipped.
I know. I just don't understand trying to sell one for $80 when they're readily available for $60. I bought mine in Jan 17 when I got my 08 and they're still available. Once they're gone and hard to find I think even a $100 would be a good deal.I think they listed and many were sold for $189. The $60 is a blowout price.
I just bought on for my 08 .
That was the case - I had to file the **** out of it, though. Looked to be an issue of chroming after manufacturing to me, because right when I got through the shiny part inside the hole it fit perfectly. Other than that my only issue was that the shift rod was good and corroded together - thanks for running a steel rod into aluminum rod ends, ma Vic. Took about 30 minutes to get that lovely corrosion freed up and spinning so I could set it to a comfortable angle.Yep. I picked one up a good while back. I don't use it often but it's nice to have it for when I wish to. Cheap enough that I still get my money worth from it.
If I remember correctly I had to file the hole in the new shifter to make it fit my bike. Just a hair but remember that if it doesn't slide right on. Works great!
