How do you like the Penske? Does it have a way to change the preload for 2-up using a trunk vs solo without? I'm back and forth on air ride or an upgraded shock.I have one from my 2016 xct. About 6500 miles on it before I replaced it with a Penske shock. PM me if you are interested.
The Penske shock is well worth it. Significant upgrade over the stock In every respect. Yes, you can adjust the pre-load, and it is fully rebuildable if you need to. Top notch piece of equipment.How do you like the Penske? Does it have a way to change the preload for 2-up using a trunk vs solo without? I'm back and forth on air ride or an upgraded shock.
The Penske is not an air shock. Adjusting the pre-load is still a bit of a pita simply because of the physical access.Do you still use a bike pump like stock or does it have an easy to reach knob?
