Thanks, that was my next stop.The Vic shop has some good videos
I have a second bike same year just like it. I tried the parts from the one that doesn't run to the one that runs and bike ran fine with the swapped parts.Any chance you have the plug wires reversed?
Did you buy it like this?
Was it running fine then all of a sudden had problems ?
Have you changed anything at all before the problems started?
I am curious as to how you checked timing, the ECM & the crank sensor?
Yes I bought it this way. History is..... to many hands have been on it.Any chance you have the plug wires reversed?
So which of the parts that worked, don't work when you use the old part?I have a second bike same year just like it. I tried the parts from the one that doesn't run to the one that runs and bike ran fine with the swapped parts.
Are you saying your running bike still runs with these parts from non running bike?I have a second bike same year just like it. I tried the parts from the one that doesn't run to the one that runs and bike ran fine with the swapped parts.
Yes every part I've tried works on the running bike. It acknowledge like the timing is way out. Checked timing it's right on. Checked valves and compression. Both good, com 150 both cylinders.Are you saying your running bike still runs with these parts from non running bike?
How are you checking timingYes every part I've tried works on the running bike. It acknowledge like the timing is way out. Checked timing it's right on. Checked valves and compression. Both good, com 150 both cylinders.
No, engine never apart. And like I said in earlier post, timing is spot on..Has someone had the engine apart? If so, you might refer to the service manual for the correct way to set up the timing. One or both cylinders could be 180 degrees out.
Rocker boxes are off crank cover off. TDC on compression stroke timing marks all line up on both front and rear cylinders.How are you checking timing
AND
Are you checking "mechanical" timing (cam to crank) & ignition timing?
All stock.Does it have a aftermarket tuner. Is it possible it went bad and throwing it off time.
I'm not that familiar with Vic's But something has to tell the coil went to spark at the correct time.Ignition timing? There's only one way to set timing, mechanical. Right?
The ECU controls the spark, but the timing wheel is the crank position sensor to let the ECU know, or believe, that the crank is at TDC. The wheel on the Vic can be re-positioned, hence altering the timing, but the ECU also changes timing, advancing or retarding, depending on the readings. It does supply signal for spark, but it needs signal to spark. Without signal, it won't spark (failsafe).I'm not that familiar with Vic's But something has to tell the coil went to spark at the correct time.
Crank position sensor on cars plus ECM looking at "other stuff".
Gotta find out what controls spark.
