Fairly new to motorcycles,
Installed new tire first time. Replaced original rear elite to cobra , front tire still have about 50% tread so I didn’t replace. First ride pretty bad wobble at 70-85 mph. Defective rear tire ?
Should I replace the front as well ?
Didn’t have it before tire replacement
Installed new tire first time. Replaced original rear elite to cobra , front tire still have about 50% tread so I didn't replace. First ride pretty bad wobble at 70-85 mph. Defective rear tire ?
Didn't have it before tire replacement
Check rear wheel alignment. Don’t go by just the marks alone on the swing arm. Once your snug spin the rear wheel and watch the rear pulley and belt how it tracks. Properly set the belt should run left to right. On the pulley wheel. 80% of the time it’s rear wheel alignment. You said no wobble before rear tire change so I’m assuming the alignment is off.
Now for the info part. What’s your front tire brand and is it bias or radial. I’m assuming the new cobra rear is radial ? If it is your generally ok with radial rear and bias front but having the same brand and tread pattern helps with tracking. Also watch your tire pressure. Cold 37 front and rear is fine. As the tires heat up while riding they will approach 39 to 40 psi warm.
Balance beads ? Rim weights ?
Thanks for all replys
It's 2011 XC , so the Aligment was slightly off I re aligned , front tire was at 26psi rear at 42 , got em both to 37 cold, front is oem Dunlop elite 3 radial , rear is Avon cobra v92 not sure if it's radial or bias with rim weight.
went for a ride still some wobble. Aligment seems still slightly off , more to one side. Not perfectly in the middle. Doubt it would make a huge difference though.
This is the front. So I both tires are Radial now. Does that mean it’s not a good thing and would possibly cause a wobble ?
I would assume front is original bikes 2012 with 10.700 miles.
I bought it last year with 8500 miles. So I didn’t even really look at the tire. Thought tires lasted longer then that , like I said pretty new to bikes. As soon as I saw how bold it was I ordered a new one
Totally agree with what others have said. Usually ok for tires to be up to ~5 years old. Older than that and you are just asking for trouble (dry rot, rubber breaking down, etc).
this is not like a car where you can have a blowout and still have 3 tires to rely on to get you stopped and pulled off the road (not that a blowout in a car isn’t dangerous too....just WAY MORE dangerous on a bike)
Look in the sipes/ tread. They are dry rotted. You new rear tire has bite and a different composition than that beat front tire. 5yrs for a tire that’s usually rule of thumb. Get rid of it. It’s done.
I suspected the front was old which is why I asked. Unfortunately the question was ignored, so I left it alone. Like I've said a thousand times, "help me, help you."
I just bought a front. Anything's got to be better than the ME888 buzzing/humming noise as it wears down. Not going back to those ever.
Related Threads
VOG Forum
1.1M posts
49.5K members
Since 2008
