Why yes....That is a 160 on the front of my XC | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by kevinx, Oct 30, 2015.
  1. kevinx
    kevinx Well-Known Member
    Sep 1, 2009
    3,229
    848
    1955 Hyda Glide
    A couple of weeks ago I spun a bearing in the 21" front wheel on my XC. So like the crazed idiot that I am. I started looking around at other brands to see what was going on. Noticing that tires were starting to get wider instead of taller these days. I decided to see what I could do on a shoestring. First I used a tire calculator, and found that a 160/60 is only about 8mm taller then a 130/70.....Then a little bit of prayer, and what the heck thinking. I ordered a cheap Perelli rear tire, and installed it backwards on the front. Looks cool as hell. Still to early to tell how I'm gonna like it, but it feels about stock comp side.JPG comp front.JPG
    • Like Like x 20
    • Winner Winner x 2
  2. Iron Ranger
    Iron Ranger Active Member
    Oct 12, 2014
    389
    247
    2012 Victory Vision
    Rollin was sure thinking outside of the box with the front tires he used on the rough roads in Alaska. If it works out for you I may try it on the Vision. Do you think it will add to the stable feeling upfront?
  3. kevinx
    Sep 1, 2009
    3,229
    848
    1955 Hyda Glide
    Feels much like stock
    • Disagree Disagree x 1
  4. Keith Grey
    Keith Grey Grouchy Old Member
    Aug 4, 2010
    7,250
    1,783
    Maryland
    None
    Exactly which Pirelli? I'm due for a front and may try this on my Vision.
  5. K1ll3m@LL
    [email protected] Well-Known Member
    Mar 6, 2015
    2,660
    797
    Lake County, FL.
    2011 Victory Cross Country
    Can you do that on stock rim and if so do you happen to know the size and have a suggestion?
  6. kevinx
    Sep 1, 2009
    3,229
    848
    1955 Hyda Glide
    Since that is my bike, and my stock rim.....The answer is yes, but it is fun to get mounted. The tire I used was chosen for price as much as anything else. I didnt want to spend a bunch, and have it not work....Here is the info from Dennis Kirk
    • Rear Angel GT 160/60ZR/18 Blackwall Tire - 2317900
    • Part # 544298
    • Price with shipping was a hair under $128
  7. racky
    racky Well-Known Member
    Aug 4, 2009
    1,054
    96
    glendale
    nice set-up kevinx, I've been wishing for a long time that some bike tire company, would come out with a 23x180- low profile tire for the front, I think that would be the ultimate in looks & handling, combined with a 200x18x50 in the rear, that way we could set up our bikes, more nascar style, instead of drag bike style, I think they would handle/corner better that way to, due to the extra rubber on the road
  8. bikendad
    bikendad Well-Known Member
    Apr 10, 2009
    6,994
    1,249
    SE Michigan
    2010 Victory Cross Country
    I like the beefy more substantial look!
    • Agree Agree x 9
  9. vanguard7
    vanguard7 Active Member
    May 25, 2015
    118
    30
    Baxter, MN
    2014 Cross Country Tour
    Why would you need to install it backwards???
  10. mdhall41
    mdhall41 Well-Known Member
    Oct 8, 2015
    528
    365
    North Carolina
    2012 Victory Vision
    I like my Judge tires, 140/90 & 160/90 on 16" rims... I've always found that a wider front and reasonable rear is the best for handling.
    Nice work with the innovative solution.
  11. Keith Grey
    Aug 4, 2010
    7,250
    1,783
    Maryland
    None
    Ordered, thanks
  12. kevinx
    Sep 1, 2009
    3,229
    848
    1955 Hyda Glide
    A rear tire and front tire have the grooves oriented opposite each other. The front needs to cut into the road, and the rear needs to push through the road. So you reverse the rear tire when installed on the front; to keep,the grooves going the right direction
    • Informative Informative x 13
    • Useful Useful x 8
  13. vanguard7
    May 25, 2015
    118
    30
    Baxter, MN
    hmmm, I figured they were directional but I would have also thought they both run same in same direction. Now I'm really curious and will have to take a closer look at the way my tires are oriented.
  14. primethious
    primethious Well-Known Member
    Aug 14, 2013
    8,027
    2,457
    2012 Victory Cross Roads
    Kevinx, You may have the only front Darkside only bike out there!
    Pretty cool, and another option for those with daring intent.
  15. kevinx
    Sep 1, 2009
    3,229
    848
    1955 Hyda Glide
    Surprises everyone when they notice it for the first time...lol
160 front tire on victory cross country
160 tires on a cross country
mean streak front tire
victory 160 front tire
