A bit of a read.
When I got my 11 XC, it had the CATS removed. It had RPW exhaust with the Lloydz GENIII controller 6250 Rev Limiter flash ECU and it had a real nice pin your ears back feeling. But the RPW pipes (great performing pipes, more during read) just didn't fit my taste for sound. Search led to the Raging Cajun pipes. When I put the Cajun pipes on it, it sounded great, but some reason it seemed to lacked the pin your ears back feeling. Put a lollipop in it because of the comments on the backpressure needed and it helped. Better, but still lacked. So I picked up a PCV and had it tuned by KevinX. Ran great, but still deep inside it wasn't the pin your ears but I thought just maybe it was because I'm accustomed to it.
Picked up a 2014 last week, rode it home, and it felt stronger. I didn't see any performance things just that it had V&H pipes. But it's redline was at 6k so it got me investigating. Initial deep peek revealed timing gear, Lloydz intake, and PCV. Digging deeper, VM1. Cool, got a better deal than I thought. I went for a ride the other day with me 2 up on my 11 and Son riding the 14. The 14 with the V&H sounds nice riding alongside. Up a bit of a grade we did a roll on in 5th and he pulled the living crapola out of me with the 14. 4th, same thing, actually worse.
Went to a friends and I'm toying in my head, hmm, likely because I'm 2 up with more weight but it didn't add up in my head. On the way back, I grabbed the 14 still 2 up, Son on my 11 and the 14 still pulled the crap outta my 11. WTF?
Yesterday Son and I did some things. Had PCV maps from both bikes so just going through scenarios. Swap maps, 14 still pulls. Swap pipes 14 still pulls although not as much. What I learned while swapping pipes is that the 14 still had it's CATS installed. The CATS are providing so much more torque at the roll arena that regardless of what I did to my 11, I couldn't roll it to the 14. I am able to get ahead during a drag from 1st gear roll starting at 2k RPM because my 11 Rev's quicker because the exhaust system flows easier but even then it's a pretty close match.
Basically, what I learned is 2 fold. The V&H pipe is a good grunt performer pipe. The Cajun is a good breathing pipe. The CAT helps a TON in the torque arena. And the RPW helps in both areas when CATS removed because I'm sure it out pulled with them on my 11 before I swapped to the Cajun.
Bike does run a bit warmer with CATS in place but I can vouch first hand side by side that the CATS need to stay.
