1 - 5 of 5 Posts
I’ve researched however I can’t find a good answer. I have a 2001 V92C with just over 19k on the clock. The issue I have is warm or cold if I let the clutch out aggressively I hear a horrendous screech from somewhere. If I feather the clutch it’s fine. Also, I lose no drive during the noise so I’m thinking it’s not in the clutch and have heard that some TC’s will make a noise. I’ve also checked and I’ve got a good newer transmission in the bike.
Ok, just found out what the rack is. Pretty much the clutch pusher pin. $102 for a new one? I might see if a machinist friend can’t make me one and the bearing is a standard size so shouldn’t be an issue. Thanks for the info MRMAXX
1 - 5 of 5 Posts
