Weird noise from below | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Vision' started by ralph, Aug 24, 2021.
  1. ralph
    ralph Member
    Jul 28, 2010
    92
    26
    New Castle
    Victory Vision & Harley Screamin Eagle Road King
    My bike sounds horrible from 2,200 - at least 4,000 rpm. I’m starting to believe it’s in the transmission. The motor itself sounds great at idle and revving while sitting still. I’ve also noticed that if I downshift to first, say around 10-15 mph, and coast there’sa funny tapping sound in the tranny. My motor is solid, 4500 miles, no oil usage, no hard state, 44.6 mpg with a passenger, etc. Could it be the tranny?
  2. Chattanooga_Mark
    Dec 25, 2009
    5,390
    2,395
    Chattanooga
    2012 CCT, Wonderful in white
    Straddle the bike at idle and with the front brake held tight lean the bike to the right and to the left. If you hear a chattering noise, turn the bike off and stop using it until you learn about the C-Clip in the transmission. If you don’t hear a chattering noise with the engine running and the bike leaned over, that’s great news. At that point you’ll move on to other testing.
  3. lou8700
    lou8700 Well-Known Member
    Dec 3, 2012
    5,794
    3,008
    St. Louis
    What year and month is your Vision?
  4. ralph
    ralph Member
    Jul 28, 2010
    92
    26
    New Castle
    14. Don’t know the month.
  5. ralph
    ralph Member
    Jul 28, 2010
    92
    26
    New Castle
    What’s the C Clip and what damage if I continue riding? Easy fix or expensive?
  6. md2420
    md2420 Well-Known Member
    May 10, 2016
    2,554
    1,128
    Chandler, AZ
    2014 Vision
  7. 08vegasrider
    08vegasrider Active Member
    Jan 16, 2021
    261
    132
    Victory vegas
    It's a 2500 -$3,000 fix at a shop. Motor has to come out.
  8. ralph
    ralph Member
    Jul 28, 2010
    92
    26
    New Castle
  9. ralph
    ralph Member
    Jul 28, 2010
    92
    26
    New Castle
    Are all of the Motors a problem that fall in that timeframe? What do they do to the motor to fix it?
  10. ralph
    ralph Member
    Jul 28, 2010
    92
    26
    New Castle
    As heavy as this monkey is, how far do I need to lean it?
  11. ralph
    ralph Member
    Jul 28, 2010
    92
    26
    New Castle
    On the side stand far enough?
  12. md2420
    May 10, 2016
    2,554
    1,128
    Chandler, AZ
    2014 Vision
    I think 08 Vegas Rider is referring to the c-clip issue. The recall I linked is different.
    I suggest you call a dealer and get them to inspect and fix under the recall. If an old Vic dealer and now an Indian dealer, they should be able to do it.
  13. md2420
    May 10, 2016
    2,554
    1,128
    Chandler, AZ
    2014 Vision
    IIRC most, if not all of the failures (if they were to happen) happened fairly quickly….like in the first 5k miles. You say you are at 4500 right now?
  14. normthenomad
    May 19, 2018
    1,087
    632
    If it's the dreaded "C" clip you have to lean it to the right, 10 to 15 degrees should do it.
    Somewhere on youtube there's a video about it. Saw it a couple years ago.
    Call Rylan.
  15. Chattanooga_Mark
    Dec 25, 2009
    5,390
    2,395
    Chattanooga
    If you hear the dreaded chattering noise with the engine idleing and the bike leaning, that’s terrible news. The engine has to come out of the frame and the engine case has to come apart to access a shaft in the transmission. It’s faster and less expensive to buy a used motor than it is to pay to have the $2 C-Clip replaced. I sincerely hope your motor doesn’t chatter when leaned over.
    The chattering noise is the gears in the transmission moving and crashing into each other because the broken C-Clip isn’t able to hold them in position. This is NOT a common problem but it’s typically very well known and feared.
    The chattering noise is also quite distinct so it shouldn’t get mistaken for a noisy lifter or any other ‘normal’ sound the 106 makes.
    • Agree Agree x 3
