WEIRD NOISE @ 3000 RPM'S | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by TOMMYSTIX, Jun 9, 2014.
  1. TOMMYSTIX
    TOMMYSTIX Member
    Jun 20, 2013
    44
    2
    RAYNHAM
    CROSS COUNTRY TOUR
    My 2013 xtour has developed a rattle like grinding sound in between shifting at 3000 RPM’s. I checked the heat shields and looked for loose parts, but no luck. Any suggestions??
  2. vision_nut
    Aug 15, 2011
    7,876
    747
    vision 08
    Your not telling us enough to understan what your noise is
  3. bubba
    bubba Well-Known Member
    Sep 27, 2008
    4,500
    59
    Denver
    2006 Kingpin
    Well based on your sig, you have a ton of things to check.
  4. red_bagger
    red_bagger Well-Known Member
    May 11, 2013
    1,181
    127
    Wenona ILL
    2012 Cross Roads 116 kit
    I wood check skid plate and belt hitting front pulley cover. I had my belt rub if two up after lowering link.
  5. TOMMYSTIX
    TOMMYSTIX Member
    Jun 20, 2013
    44
    2
    RAYNHAM
    CROSS COUNTRY TOUR
    OK... The noise sounds like vibratiing metal that is heard from the front of the engine through the fairing. It only occurs at 3000rpms and mostly before switching gears. Cruising at 3000rpms in fifth and 6th gear the same noise will appear, but will go away once under or over the 3000rps. I see many noises like this come into the shop on cars that results in a loose cat shield, but nothing seems to be loose.
  6. TOMMYSTIX
    TOMMYSTIX Member
    Jun 20, 2013
    44
    2
    RAYNHAM
    CROSS COUNTRY TOUR
    aahhh.... I didn't think to check the skid plate.. Thanks
  7. TOMMYSTIX
    TOMMYSTIX Member
    Jun 20, 2013
    44
    2
    RAYNHAM
    CROSS COUNTRY TOUR
    RED_BAGGER YOU ARE THE MAN!!! The rear bracket on the skid plate broke and was causing the noise. I called Witch Doctors and they are sending me another one out today at no cost..... Thanks for everyones help and to Witch Doctors GREAT CUSTOMER SERVICE!!
  8. red_bagger
    May 11, 2013
    1,181
    127
    Wenona ILL
    Glad you found the problem. I dont have one on my bike butt I have read alot on here about people havivg them brake. And you are right about WD they are great . They take care of every body the way it should be done.
