Folks looking for a little help had the Steering head bearing changed manual said too:
Turn lower clamp fully right against steering stop and torque
stem nut to 29.0 ft-lbs (39.3 Nm).
Turn steering assembly fully left and back to full right 5 times.
[§J Turn lower clamp fully left against stop.
[1J Place a mark or tape on frame, in direct alignment with one of the slots of the adjuster nut.
Loosen adjuster nut 90 degrees (a new slot of nut should now be aligned with the mark or tape placed on the frame in Step 6).
All that was done now there is a weave and wonder at around 80 kph under trouble shooting the manual it says
Steering Stem Nut Over Tightened or Under Tightened
Torque to specification
would anyone know if this is more of a over tightened problem ? i
Thanks for ther help!!
