Anyone running either of these fuel pumps? If so, how much of a Pain in the butt was it to install?
It has occured to me that maybe they think mechanics are installing these. But my question was pretty easy and quick. Just bad customer service seems to me.I understand that a couple of persons have purchased and installed the Quantum pumps on Victory motorcycles but none of them went into detail about the procedure they followed. Maybe an energetic person will document the procedure next time and post it. As for the supplier maybe they just assume that the person purchasing these parts for a fuel pump must have some "skills"?
I wasn't able to find a Walbro fuel pump for Victory. Where did you see them?Anyone running either of these fuel pumps? If so, how much of a Pain in the butt was it to install?
I'm in Mohave County.Found them on ebay. Just type fuel pump for your year and model victory fuel pump, a whole gang of vendors will pop up.
Where are you in AZ? I'm not far from Benson.
I used a knife bent (see picture) it is a handy tool to get the pump out ..Folks l appreciate the videos. But the question is, "Has anyone used the Walbro or the Quantum pump." I don't have a problem with R&R the pump. I'm pretty sure there will be some mods if l try one of these pumps. That being said I'll try to post pictures of how it goes and how it performs. Think l"'ll probably go with the Walbro pump, filters and regulator for around $130.00. Be awhile to get to it. Stay tuned.
Mine is an '06 has the round access. Bought.the Hammer in Kingman.If you look at the Walbro or Quantum fuel pumps you can see they look similar to the stock OEM fuel pump in their mounting bracket.
Once you pull the old one out you simply change out the pump and re-secure it with cable ties.
So simple a caveman can do it.
Yes it is, thanks.
Sorry forgot to say, of cource "blunt" grind the knife nice and round-smooth ... But that should be logicalYes it is, thanks.
