Voltage Regulator Up In Smoke | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by toddatc22, Nov 25, 2020.
  1. toddatc22
    toddatc22 Member
    Dec 13, 2016
    36
    26
    GA
    Cross Country
    I have had an issue with it in the past and my voltage was jumping around. I replaced with an OEM replacement and it worked well for two years.
    Out on a ride this week voltage starts jumping around again, but this time I hear a pop and then smoke. Smoke seems to be coming from the voltage regulator and dripping plastic on the ground. I have no power to anything anymore at all so I am concerned there is more damage. Where should I start with electrical testing?
    Thanks in advance. I just moved to phoenix today, if anyone is in the area and has shop recommendations please let me know.
    Thanks
  2. VicVisionBulldog
    Mar 27, 2011
    19,621
    8,882
    Houston
    @md2420 is in Chandler which looks like is right there at Phoenix.
    Did you already switch out the burned up unit?......and still have no power to anything?
  3. toddatc22
    toddatc22 Member
    Dec 13, 2016
    36
    26
    GA
    Cross Country
    I have not....I am ordering the SH847 from a write-up on here. I just do not remember if all power should be completely wiped because that part is fried.
  4. VicVisionBulldog
    Mar 27, 2011
    19,621
    8,882
    Houston
    I don't know for sure but it certainly makes sense to me that it would be.
  5. md2420
    md2420 Well-Known Member
    May 10, 2016
    1,836
    791
    Chandler, AZ
    2014 Vision
    ive only been to a couple of shops here.
    1) BFP Garage in Glendale. Brad is a good guy and does work out of his own place. You can see what he can offer.
    2) Phoenix Triumph (in Mesa). They used to be a Vic only shop up until the closing. Then switched brands, but still work on Vics.
    3) RideNow Powersports. One in Chandler and one in Peoria. Both were Vic dealers and now Indian dealers.
    • Useful Useful x 3
    • Informative Informative x 2
  6. 1stVictory
    1stVictory Well-Known Member
    Feb 14, 2012
    6,139
    1,475
    Edmonton, AB
    2012 Pearl White CC Tour
    I’ve always believed that electronic components use smoke inside to make them work as they do. But if the smoke is released, so is the hope of them working anymore. An example was many years ago trying to set the small switches on a hard drive. Suddenly, smoke was released and it didn’t work anymore. :22yikes:
    • Funny Funny x 3
  7. Motorbikerx
    Motorbikerx Well-Known Member
    Dec 27, 2013
    399
    404
    Gold Coast, Australia
    2010 XC
    Mine failed on the Vegas a while back.
    Did the update to the better SH487
  8. IndyVictory
    IndyVictory Well-Known Member
    May 29, 2020
    689
    259
    Indianapolis
    SH487:
  9. VicVisionBulldog
    Mar 27, 2011
    19,621
    8,882
    Houston
    He is down under so many times things get twisted. They have to post pictures upside down so we see them right side up here. It is not his fault.
    • Funny Funny x 2
  10. Pauljp
    Pauljp Well-Known Member
    Nov 28, 2013
    1,125
    671
    Quebec Canada
    2014 Cross County Tour
    The voltage regulator is only in operation while the bike is running as it gets its power from the stator.
    While the bike is not running the only source of power is from the battery.
    Check the battery first, unless it is totally dead the next place I would look is the main 40 amp circuit breaker located beside the battery. If it's fried then you would have absolutely no power to the rest of the bike.
    Good luck and keep us posted.
  11. Known1
    Known1 Well-Known Member
    Apr 30, 2012
    4,421
    1,436
    Cement Slab, MN
    2013 Cross Country Tour
    For his sake, I hope that the 40-amp breaker fried when the R/R let the blue smoke out. If not...uh oh!
    I personally think it is mostly heat that kills the OEM R/R. Maybe I'm putting too much thought into it and they are just pieces of crap in general? I'm on my 2nd OEM unit and have about 60k miles on it so far. Something tells me I'll be replacing it next season, as I've clearly jinxed myself now.
    • Funny Funny x 1
  12. Motorbikerx
    Dec 27, 2013
    399
    404
    2010 XC
    SH847
    Yeah man I screw up all the time, being upside down all the blood rushes to my head!
    Unless Im having sex of course
    • Funny Funny x 3
  13. mastrblastr
    mastrblastr Active Member
    Sep 15, 2015
    212
    151
    BC Canada
    2011 Victory Cross Country Tour
    PaulJP, you are correct. When my regulator crapped out, I was at a gas station and I still was able to ride my bike home as I was only 4 blocks from my house. Replaced with an RMStator regulator and it has been fine for years.
    I'm thinking that 40 amp breaker (or the wiring around it) is the reason for no power, as the regulator is right there and gets damn hot when you release the smoke. Damn those things stink when they let loose!
  14. Flyboy
    Flyboy Well-Known Member
    Aug 29, 2014
    14,731
    5,584
    Victory Boardwalk
    I agree with the logic of the mystical powers of the smoky mist as it has been witnessed often with the harnessing of electrons on all modes of transport and home appliances....
    My issue is that the Gremlin that released the mist moves on to other areas to do it again, once the mystical powers have been restored to the item in question.
    About to reengage with one that has been a costly hunt as he mocks my efforts in a German Auto:
    55A80334-6052-4571-B9BE-CC6360191CF6.jpeg 7CE8B1D3-3D13-4DE0-8FA5-B61D4D88BCFD.jpeg
    • Funny Funny x 3
  15. toddatc22
    toddatc22 Member
    Dec 13, 2016
    36
    26
    GA
    Cross Country
    Well the regulator is definitely bad and so is the battery which would explain no power at all now. 6163A61A-238E-4261-867B-53818735BF64.jpeg 21CAEE8F-0721-4B7D-AD0C-0C8F89DB3841.jpeg
