Victory Race Bike | Page 3 | Victory Motorcycles: Motorcycle Forums
Victory Race Bike
Discussion in 'Victory General Discussion' started by Unfinished_Projects, Jul 21, 2021.
  1. jmstang302
    jmstang302 Well-Known Member
    Aug 18, 2013
    5,442
    2,270
    Littlestown
    I don't have Instagram. I was able to watch.
  2. normthenomad
    May 19, 2018
    1,029
    575
    Watched the clips several times. Noticed I was touching myself after the third time so I had to quit!
    Thanks. Really like the shredded rear tire, shows you really mean it.
    • Funny Funny x 1
  3. normthenomad
    May 19, 2018
    1,029
    575
    Went over to a friends and watched it. Wouldn't come up on my phone, wanted me to create an account.
  4. normthenomad
    May 19, 2018
    1,029
    575
    Changed rating to winner after seeing instagram post.
  5. ZebraUp
    ZebraUp New Member
    Sep 27, 2020
    4
    5
    Hammer & Big One
    You running CCS or WERA or ???
    <--- Army vet.. & former CCS & Formula USA racer..
  6. RT Thor
    RT Thor Active Member
    May 10, 2016
    149
    148
    2014 XC, 2007 Hammer S
    What is your general rpm operating range? If I was guessing 3500-5500 with current set up. I'm thinking some S&S/Lloydz .495 cams with a reworked third gear customs intake (better peak power above 5000ish than TTI). We could get by with a PCV, a Maximus would be better (but I have the PCV already and the price is right,,,,,Free)
    I currently have the used cams, new springs, the intake and PCV. So all we need to do is figure a way to get the bike to Texas after the season.
    I'll drop the motor, pull the heads, do a little port work, change the springs, install the cams, get the ecm reflashed for 7000 rpms and then tune the girll up. Then get it back to you.
    Easy day.
    • Winner Winner x 3
  7. jmstang302
    Aug 18, 2013
    5,442
    2,270
    Littlestown
    @RT Thor , wouldn't higher compression pistons be worth a few more ponies? If you’re pulling the heads I think they would be worth doing?
  8. normthenomad
    May 19, 2018
    1,029
    575
    If I ever make any real drastic mods that'll be one of the prerequisites. I think you'd get much more bang for the buck than the big bore kit.
    Looked at a lot of dyno sheets here and just can't justify the expense for the power gain from the 116".
    Seems like higher compression, cams, better air flow: bigger valves and headwork would yield a lot more for the money.
    No, I did'nt forget fuel management. Maximus for sure.
  9. RT Thor
    May 10, 2016
    149
    148
    Yes it would be worth a few more hp, but then you have a added cost as well. In my opinion not the best bang for the buck.
    I have included my v92 ebay build as an example of well thought out combination on the cheap, but solid.
    The bike is a 03 v92 with a
    -100" big bore. Not a kit but just some 100" jugs (off ebay for $80, but when the guy shipped them it broke a couple of fins off so got them for free) with late model 106 pistons.
    -used .495 cams off ebay for $120
    -ebay Bassani road rage exhaust $240ish
    -merger collector was giving to me
    -Autozone 3" pipe with a 2.5" reducer $17
    - Used Barnett heavy spring and pressure plate $50ish
    -New PCV $299 Motomummy
    -Used gen 1 Third Gears intake that I ported to match 48mm throttle body $200
    -48mm throttle body that i did years ago for flow testing maybe i paid $250 at the time.
    -New high lift springs $130 ish.
    -bowl work on the heads. The throttle body is not worth power, but my stock throttle body boot was cracked so the only boot I had was the one for the 48mm TB so I just put the tb and boot on.
    -ECM reflash by Rob'd Dyno Service $300
    My price list may be off some but all of it was great deal, mostly of ebay.
    Makes real good power for pennies on the dollar. It took a lot of testing on exhaust to get to this level.
    I have rode it from Texas to Maryland twice, once pulling a trailer.
    Really long post to say that, you are correct. However, I think that we can add some much needed power in the right rpm window to add to the fun factory without jacking up the cost. 20210729_121153.jpg 20210729_121349.jpg
    • Winner Winner x 2
