Vic Keyless with Alarm or DGD Plug n play? | Page 3 | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by ralex420, Jan 31, 2016.
  1. AK_CrossRoads
    AK_CrossRoads Member
    Aug 4, 2013
    33
    12
    Cross Roads
    Following the link makes these things $70 more expensive, am I missing something?
  2. ralex420
    ralex420 Active Member
    May 17, 2015
    118
    83
    Peoria, IL
    13 Ness XCT
    I'll heat my garage on Sat., install and report
  3. ralex420
    May 17, 2015
    118
    83
    Peoria, IL
    13 Ness XCT
    I found several links for the same product, most of which were in the $200 range
  4. Guitardedcow
    Guitardedcow Member
    Oct 18, 2013
    92
    41
    Calgary
    Victory Cross Country Tour
    If you lose your original fob and just have your 'not yet programmed' spare fob, you are going to make a lot of noise. Same goes if you take your stock key ignition system with you as back up. Once you disconnect the module, the alarm will go off. No way around it, if you lose your fob, your going to make a lot of noise.
  5. Guitardedcow
    Guitardedcow Member
    Oct 18, 2013
    92
    41
    Calgary
    Okay, I have a correction to make. My wife just pointed out to me that I could program the second fob and just let it run out of battery over the period of a couple of weeks and put it, and an extra charging cable, in one of my saddle bags. Then when or if I lose my primary fob, I simply find my secondary and plug it into a power source, after about 20 seconds, I can start my bike and continue charging my replacement fob.
    Let that be a lesson to me, if I really need a practical answer, I should ask my Saskatchewan born MRS.
  6. vickpin
    vickpin New Member
    Oct 15, 2011
    17
    3
    Minnetonka
    2013 Victory XCT
    Installed the Victory key-less ignition June of 2015 in my XCT. The unit came with 2 fobs. One fob would not hold a charge after a couple or weeks and left me stranded until the working fob was run out to me. My Vic dealer ordered a replacement fob that was received 6 weeks later, (No backup fob during that time) All was fine for the next month and then the new fob would not hold a charge. Had my dealer order another fob but after a few weeks I decided to uninstall the unit and return it for a refund. I would not recomend the Victory Key-less ignition.
  7. ralex420
    May 17, 2015
    118
    83
    Peoria, IL
    13 Ness XCT
    It warmed up here in IL! I just installed the Vic Keyless/Alarm was super simple to install.
    I made the mistake of bumping my scooter right after the install. What a crazy piercing noise! I hadn't read anything about arm/disarm at that point.... Luckily I hadn't replaced covers and seat yet and I just unplugged that sumbitch real quick!
    I will adjust the settings to avoid that sort of incident in a parking lot elsewhere. So, IT WORKS!
    I'm riding a little over 4 hrs to The Vic Shop tomorrow. Gonna get my Dyno-Tune on!
  8. caw391
    caw391 Member
    Oct 21, 2013
    153
    10
    North Las Vegas, NV.
    2013 Cross Roads Classic
    Their regular price is $459.00. So the Victory owners price is a decent discount. Be sure you're looking for the DGD-KIM-V2 for VISION / CROSS ROADS / CROSS COUNTRY. Be sure to look at the one for your specific model. Digital Guard Dawg - DGD-KIM-V2 Keyless ignition & security for motorcycles
  9. jpickar
    jpickar Member
    Mar 3, 2015
    40
    7
    Baraboo, WI
    2014 victory Cross country
    Question on factory Victory keyless/alarm can you use the original key and key cylinder ignition in place of the keyless ignition part that comes with the system?
  10. ralex420
    May 17, 2015
    118
    83
    Peoria, IL
    13 Ness XCT
    I'm a bit lost. The whole purpse of this kit is KEYLESS IGNITION. The Alarm aspect is just added value. If you just want an alarm, there are probably less expensive options available. Probably via GuardDawg
  11. Slappy
    Slappy Active Member
    Jul 22, 2012
    200
    37
    Murrells Inlet, South Carolina
    2012 Cross Country Tour
    No. there is no "Y" connector provided . The push button gets mounted where the factory key is mounted on the wedge, the cylinder is disconnected from the harness and the keyless wiring gets plugged into the harness. I keep the key cylinder in the saddle bag in case of keyless system failure It can be swapped back pretty easily.
  12. jpickar
    jpickar Member
    Mar 3, 2015
    40
    7
    Baraboo, WI
    I don't want to High Jack this thread, because there is a lot of great information here. So sorry for any problems..
    I just watched an install video yep I understand know about the harness!
  13. jpickar
    jpickar Member
    Mar 3, 2015
    40
    7
    Baraboo, WI
    my thought is totally opposite of yours. I would perfer the alarm aspect over the keyless ignition. My understanding is the Guard Dawg has no alarm!?
  14. ralex420
    May 17, 2015
    118
    83
    Peoria, IL
    13 Ness XCT
    Scorpio SR-i900R Security System
    This appears similar to the Victory parts I installed (sans key cylinder)
  15. jpickar
    jpickar Member
    Mar 3, 2015
    40
    7
    Baraboo, WI
    To be honest it's the exact same Scorpio unit except for the wiring harness which Victory went to another distributer/supplier for. Don't get me wrong the Victory keyless is a great product just looking for the answer if the key cylinder would work in place of the push button start? Edited:: just watch a install video never mind will not work! Thanks tho
plug and play keyless ignition victory vegas 2017
victory magnum alarm
