Hi there new to site bought a 1999 v92c about two weeks ago.I purchaced it not running and after doing throttle body cleanout i noted front small port is blocked. I could not clear blockage but reassembled with new plugs and did throttle piont reset and did static reset. My problems seemed fixed for the most part i could ride it . it seemed to run rich clasic victory storybut only died on occasion and started up easily
then this morning no start not a cough. i check for spark and nothing, new plugs already black sooty. So i get new plugs and still no spark check to see voltage present at coil inlet 12v. Coils and crank timing sensor ohms readings are in normal range. re assemble and still no spark i have 2 batteries and both have 12.5v (only one on the bike at a time). i do notice it my rear plug boot doesnt click down but plug inserts to same depth. I have to say the ride even not running like it should was a blast. has anyone had simular issues any sugestions on how to remove throttle body obstructions.
