V92c engine code | Victory Motorcycles: Motorcycle Forums
V92c engine code
Discussion in 'Other Victory Models' started by Ed E, Oct 12, 2014.
  1. Ed E
    Ed E Active Member
    Oct 11, 2014
    158
    70
    SW Virginia
    2016 XCT
    I am trying to lay up some spare parts for my 1999 V92c. I found a low mileage engine and transmission (allegedly good...) with the code MCVT1507D-02. The guy who is selling it thinks it is from a 1999, but I am uncertain since this is different than the code on my bike. Does anyone know what the code tells me about the engine?
  2. Ed E
    Ed E Active Member
    Oct 11, 2014
    158
    70
    SW Virginia
    2016 XCT
    I think I answered my own question. The 1507cc displacement would put it as a 2002 or later engine, not a 1st generation 1500cc. This would make it the first of the Freedom series, as I understand it.....
  3. kevinx
    kevinx Well-Known Member
    Sep 1, 2009
    3,230
    844
    1955 Hyda Glide
    99 was also 1507. Got a picture of the motor you are looking at?
  4. Ed E
    Ed E Active Member
    Oct 11, 2014
    158
    70
    SW Virginia
    2016 XCT
  5. Ed E
    Ed E Active Member
    Oct 11, 2014
    158
    70
    SW Virginia
    2016 XCT
  6. Ed E
    Ed E Active Member
    Oct 11, 2014
    158
    70
    SW Virginia
    2016 XCT
  7. Ed E
    Ed E Active Member
    Oct 11, 2014
    158
    70
    SW Virginia
    2016 XCT
    The code on my '99 engine is MCVT1500D-01. It was sold in Jan of 1999.
  8. kevinx
    Sep 1, 2009
    3,230
    844
    1955 Hyda Glide
    First that is a first ten engine, and defiantly not a freedom. The drive pulley tells me it is a 99-00 engine. Hard to see the finish on the engine. If it is smooth and glossy it is a 99. If it is textured and matte. It would be an 00
  9. Ed E
    Ed E Active Member
    Oct 11, 2014
    158
    70
    SW Virginia
    2016 XCT
    Thanks Kevinx, that is very helpful. I am pretty sure the motor itself is ok. The tranny is the big unknown, and that is a key point of interest to me. I think I can pick it up fairly cheap, so I may just take a flyer on it.
  10. kevinx
    Sep 1, 2009
    3,230
    844
    1955 Hyda Glide
    Trans update has NOT been done
  11. Ed E
    Ed E Active Member
    Oct 11, 2014
    158
    70
    SW Virginia
    2016 XCT
    I think I will wind up keeping my eyes open for a 02-05 Freedom motor/trans with a more certain history. Seems to make the most sense.
  12. jodylaster90
    jodylaster90 New Member
    Jul 13, 2020
    3
    2000 v92sc
    Is there anyway to tell if the transmission upgrade has been done from looking at the outside. My bike also has the number mcvt1507d-02 and I was told that when the bike went to the dealer for the recall the guy paid the difference for a new engine and an entire new transmission
  13. KLA
    KLA Well-Known Member
    Jun 4, 2017
    711
    329
    Lawrence, Pennsylvania
    2007 Victory Jackpot, 1999 Victory V92C Classic
    The placement of the speed sensor will tell you if the upgrade has been done or not. I believe that if the speed sensor is pointing at the drive pulley/gear on the right side of the motor then the upgrade has been done. If the speed sensor is more towards the middle of the motor on the back of the case behind the rear cylinder then the upgrade has not been done and the engine is original.
    Good luck! Hope this helps
1999 victory v92c check engine
1999 victory v92c trouble code
clear engine code victory v92c
ebay motors motorcycles victory 92 v92c pilar 1992
fail codes for 99 victory 92c
how to check engine code on a 2000 victory 92
how to check engine code on a 2000 victory v92c
how to clear codes on a 2000 victory v92
list of error codes for 2002 victory v92c motorcycle
mcvt1507d-02
motorcycle troubleshooting codes for victory v92c
victory motorcycle code ch eng
