Underdrive pulley pros/cons | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by Kinger08, Jan 13, 2021 at 8:28 AM.
  1. Kinger08
    Kinger08 Member
    Sep 20, 2019
    72
    10
    2008 kingpin
    I see that custom concepts has an underdrive pulley for the cross country’s. Amy thoughts on these, I’m sure they will change the speedometer a bit but I can get use to that.
  2. md2420
    md2420 Well-Known Member
    May 10, 2016
    1,820
    785
    Chandler, AZ
    2014 Vision
    Many many threads and discussions here on the UDP. See below “similar threads” and also do a site search for it. Then buckle up and read read read.
    btw - it’s Conquest Customs that has the UDP. If you decide to go that route, get theirs...not some cheap knockoff. Another member on here got one from a diff source and the internal splines sheared from the poor metal/build quality.
    • Agree Agree x 7
  3. wvrider1
    wvrider1 Well-Known Member
    May 20, 2012
    3,522
    1,086
    WV Appalachia
    Goldmist/Black 14 XCT
    pro
  4. iabob
    iabob Well-Known Member
    Dec 20, 2010
    16,584
    5,079
    Des Moines
    Victory Kingpin
    Cons: your speedo will be off 7%, unless you also install a Speedo Healer. The motor now spins at 3210 rpm instead of 3000 rpm to maintain approx 80 mph. You probably don’t want your wife to know what it costs, unless you chose wisely and she doesn’t care.
    Pros: you will find a lot of talk about this doing a search and reading the many threads. To get technical gearing multiplies power. If you’re familiar with riding a 10 speed bike imagine a race where you clock your 0-20 mph time. First try it shifting from 2-4-6-8-10. Next try it going from 1-3-5-7-9. Your legs are making the same amount of power, but the gearing multiplies it to accelerate the bike faster. The difference is in 9th your legs are spinning faster than in 10th. On the motorcycle, you will accelerate faster. And the motor will be spinning 7% faster.
    I actually don’t think spinning 7% faster is bad. I always thought 6th gear on a Vic was too tall, it didn’t seem useable until over 70 mph. Now if I’m on a 2 lane highway doing between 60-70 I can actually be in 6th.
  5. Kinger08
    Kinger08 Member
    Sep 20, 2019
    72
    10
    2008 kingpin
    I tried the search thing and it comes up with pages of other topics, maybe I’m not hitting the rite keyword, too technical for this old fart.
  6. Kinger08
    Kinger08 Member
    Sep 20, 2019
    72
    10
    2008 kingpin
    Never heard of the Speedo healer.
  7. md2420
    May 10, 2016
    1,820
    785
    Chandler, AZ
    2014 Vision
    @Kinger08 ive found the best way is to search “titles only” and that helps. Also check the box that says this forum only and display as threads.
    Separately, you could just do a Google search for the vog site specifically and that can help too. Just type “site:thevog.net underdrive” in the search bar. That will only bring back results from this site.
    site:thevog.net underdrive - Google Search
  8. iabob
    Dec 20, 2010
    16,584
    5,079
    Des Moines
    Victory Kingpin
    They’re made for most any brand. Conquest also sells them. I haven’t put one on my bike, kinda got used to just knowing the speedo is reading a few mpg faster than I’m going. But it’s one of those things I think I’ll get around to one day.
  9. Half_Crazy
    Half_Crazy Well-Known Member
    Aug 23, 2008
    23,309
    9,422
    Great Mills, MD
    Bikeless
    The speed limit is just a suggestion...
  10. Half_Crazy
    Aug 23, 2008
    23,309
    9,422
    Great Mills, MD
    Bikeless
    There are no "cons". Top gear on the highway:
    what was 2500 rpm before will be 2675 after
    what was 3000 rpm before will be 3210 after
    what was 3500 rpm before will be 3745 after
    Like going from 3.55 rear gears to 3.73 in a car. A small change.
    6000 rpm in 5th gear still equates to 145-ish mph (if you had the power to pull it). You can still cruise at 100 mph for as long as you want.
    You would still finish a 1/4 mile drag race in 4th gear.
  11. benawhati
    benawhati Active Member
    Feb 16, 2017
    548
    204
    Ohio
    2017 Vic Gunner/2011 VIc XC "Tour"
    Pros-endless smiles
    Cons- wrinkles from so much smiling
    • Winner Winner x 3
  12. Kinger08
    Kinger08 Member
    Sep 20, 2019
    72
    10
    2008 kingpin
    Thanks for all the info fellas. So I’ve read that it takes a 48mm socket to get the pulley nut off, no problem with a little heat. My question is how do you hold the engine from rotating while taking it on or off, guess I’ll be using an air impact.
  13. wvrider1
    May 20, 2012
    3,522
    1,086
    WV Appalachia
    I pulled the timing cover, then you need 5/16 punch to put crank hole. Torque is 180 ftlbs. on the nut. Most 1/2 TW only go to 150. Check yours.
  14. broggyr
    Apr 28, 2013
    1,372
    503
    Connecticut
    2013 XCT
    I used an impact to take it off and put it on, but then I held my foot on the brake pedal when I was torquing it to spec.
  15. Kinger08
    Kinger08 Member
    Sep 20, 2019
    72
    10
    2008 kingpin
    Cool thanks, I have a TW that goes to 325 foot pounds so I’m good there.
