I know this question has reared its ugly head before But i started hearing a slight clunk in trans when shifting and letting out on clutch. Any thoughts??
Very common on a big bore bike.I know this question has reared its ugly head before But i started hearing a slight clunk in trans when shifting and letting out on clutch. Any thoughts??
Otherwise know as "blipping the throttle". Works for me though many don't believe in it. Too big a blip can cause the engine to die when downshifting. So blip a bit and you'll be ok....try rev matching
This works but does have a learning curve. Practice. Less tends to be more. Light touch up top and authoritative push/pull below. Follow through is important. And timing!Otherwise know as "blipping the throttle". Works for me though many don't believe in it. Too big a blip can cause the engine to die when downshifting. So blip a bit and you'll be ok.
That is excellent to hear. How much of it do you think is the machine versus you in those 90,200 miles? In other words, what have you changed when it comes to riding your bike over all of those miles? I suspect the machine hasn't changed much, yet your're noticing things are better and smoother than ever. I suspect it is all you man and you may not even realize it.I was asking the same question back when I first got my XR four years ago with 1,800 miles on it. Seriously, Just today I took it for a short ride and was thinking that with 92,000 miles it's working better and SMOOOOOOTHER than ever.
Yes, I suppose you might be right. After a lot of saddle time on any machine you tend to get a feeling for each other and learn how to keep each other happy. I had just finished a 20 day 7200 mile trip of the west and believe me I was feeling as one with my machine. lolThat is excellent to hear. How much of it do you think is the machine versus you in those 90,200 miles? In other words, what have you changed when it comes to riding your bike over all of those miles? I suspect the machine hasn't changed much, yet your're noticing things are better and smoother than ever. I suspect it is all you man and you may not even realize it.
