transmission problems | Victory Motorcycles: Motorcycle Forums
Discussion in 'Victory Cross Country' started by Simo495, Mar 20, 2016.
  1. Simo495
    Simo495 New Member
    Mar 20, 2016
    3
    2013 Victory Cross Country Tour
    Hi , I have a 2013 cross country tour with about 11000 miles. This morning I could only shift from neutral to first and could not shift up to second any ideas what could be wrong? I have notice the last couple of days it's been a little harder to shift into second and the noise was louder ( the big bang).
    Simo
  2. 1stVictory
    1stVictory Well-Known Member
    Feb 14, 2012
    5,680
    1,263
    Edmonton, AB
    2012 Pearl White CC Tour
    You have a heel shift adapter on it? Maybe not enough room to do a decent engage.
  3. Flyboy
    Flyboy Well-Known Member
    Aug 29, 2014
    13,768
    5,081
    Victory Boardwalk
    I just found during my 6000 mile oil change and check-list a loose fitting on the shifter shaft from the engine. Worked loose and put some lock tight and retightened. With the floor boards could have shifted out of range from slippage.
    Clutch adjustment? If not hydraulic...
  4. vision_nut
    Aug 15, 2011
    7,933
    871
    vision 08
    is your cable adjust right. you can only adjust it when its over night cold. never warm or hot
  5. Simo495
    Simo495 New Member
    Mar 20, 2016
    3
    Yes I have a heel shifter. I will have to check. I was so pissed off I haven't look at it closely yet. I have hydraulic for the clutch for about a year now, works well .
    Thanks
    Simo
    Ps, any more ideas would be a big help! I was thinking maybe the ratchet fork could be the problem. Give a men the service manual and he becomes dangerous.
  6. Keith Grey
    Keith Grey Grouchy Old Member
    Aug 4, 2010
    7,252
    1,778
    Maryland
    None
    Check the in and out play (axial) of the shifter shaft where it goes through the case into the engine. Also, there may be something in this video that makes better sense than a 2 dimensional manual. Either way, check the entire linkage for loose fittings and sufficient room to move in case it has slipped.
  7. Simo495
    Simo495 New Member
    Mar 20, 2016
    3
    This video was very helpful. knowing now that this could be the problem is very relieving. I will have some time this week to check and I will let everyone know what I find.
    Thanks
    Simo
  8. tyrfryr
    tyrfryr Well-Known Member
    Aug 20, 2014
    703
    269
    Nebraska
    Cross Roads Classic
    Would agree with a check of heel shifter clearance, had same problem after bushing replacement, the shifter was hitting the support. Found I had dropped the washer, (spacer) between the support and shifter, ya kinda gotta hate when your human shows.;)
  9. Mikewillride
    Mikewillride New Member
    Nov 24, 2019
    8
    2
    Victory cross country
    This vid was very very good, thanks a lot for posting
  10. slickvic
    slickvic Well-Known Member
    Dec 22, 2011
    9,757
    3,803
    South Florida
    2011 Cross Country
    It is 3 yrs old but still one of the best help videos on our forum. Miss Keith.
  11. Rollinwind
    Rollinwind Active Member
    Jan 10, 2020
    115
    30
    Magnum
    Obsolete. There is a new and improved shift shaft assembly that eliminates need for washer.
  12. slickvic
    Dec 22, 2011
    9,757
    3,803
    South Florida
    2011 Cross Country
    What source can we pick this up from sir.
    Was also wondering if any of the newer models already come with it. My 16 Magnum shifts way smoother than my 11 XC does.
  13. Flyboy
    Aug 29, 2014
    13,768
    5,081
    Victory Boardwalk
    What year?
  14. Rollinwind
    Jan 10, 2020
    115
    30
    Magnum
    The new part was made available 2018 Winter far as I know. At least that is when the part number changed. My Magnum shifts great too. If not at WD I go here. Victory Parts - VictoryParts.net To see the real discounted price you have to add the part to the cart.
2010 victory cross country transmission manual
2013 victory cross country problems
2014 victory boardwalk problems
2014 victory cross country tour problems
crossc country tour check transmission
victory motorcycle 2010 vs 2011 transmission
victory motorcycle transmission problems
victory motorcycle transmission recall
victory motorcycles transmission problems
victory transmission issues
what transmission is in a victory cross country tour motorcyle
