I have a 2005 V92TC, while replacing the clutch cable I had to remove the transmission/primary cover. (I don't remember if I had to or if there was some other reason why I took it off as the bike has been sitting for some time now) I had someone helping me with all this and when It came time to properly torque the bolts on the cover we didn't have an inch lbs torque wrench on hand so we made due with a ft lbs wrench and did a little math to figure out the correct torque. (Our math was wrong BTW) Knew something was wrong when the torque wrench was not clicking at all. It was then I realized we had screwed up. Went and bought the correct torque wrench and torqued the rest of the bolts. Now oil leaks out from around that one bolt and I don't know what to do. Could we have cracked the transmission housing? Just stripped it out? I don't know, any helpful criticism would be appreciated.
