1 - 13 of 13 Posts
Was out riding today and went to downshift from 2nd to 3rd and I got what sounded like a chattering or ratcheting sound , I pushed through and it dropped to 1st but with a clunk? Any ideas it will still do it it if I put light pressure on shift lever but won’t if I apply a good amount of pressure and push through. I had my 10,000 miles service done about a 1,000 miles ago. Any help will be appreciated thanks.Again it’s only between 2nd down to first .
You have to be assertive when shifting a Vic. Some more than others but they are nothing like a lot of the Asian brands which shift smooth with barely a click.
I believe half the problems people have with Victory transmissions is they sort of half shift instead of putting their toe or heel into it.
It’s weird it just started to do it. I normally use same strength and pressure down shifting all the way down to first but now it takes a little more from 2nd to 1st. Just wondering if that’s normal with these bikes to do that after 10,000 miles? It sure has no problems up shifting lol.
I usually don't downshift to first until almost at a complete stop. It wasn't until after 50k that it seemed to be getting a little rougher to shift and I noticed the shifter had a lot of play in it. I installed the brass shifter bushings I got from Witchdoctors and it seemed much smoother. 95k and it still feels fine. Some have had issues with the shifter ratchet and also installing a washer to tighten things up. If you do a search for Shifter Ratchet on here you will find a few good threads.
Was out riding today and went to downshift from 2nd to 3rd and I got what sounded like a chattering or ratcheting sound , I pushed through and it dropped to 1st but with a clunk? Any ideas it will still do it it if I put light pressure on shift lever but won't if I apply a good amount of pressure and push through. I had my 10,000 miles service done about a 1,000 miles ago. Any help will be appreciated thanks.Again it's only between 2nd down to first .
You might be having problems with the bushing on your shifter. They aren't metal, and tend to gum up a little. Suggest taking a close look at that area.
I have gotten this too occasionally. I find that I can avoid it by being more assertive with my downshifts and making sure I'm not downshifting too early. I also don't downshift into first anymore until I'm at a stop. And that shift into first either from neutral or 2nd has always resulted in a huge clunk on both my Victory's. That's the nature of the beast I suppose.
Excellent point. Another common issue is the ball joints on the connecting rods must be lubed regularly or the shifting will act up as well. I like to use a white synthetic grease on those joints. It seems to stay on longer.
Thank you , will try the grease but I already did the brass bushing swap.
I know when I did the brass bushing it was a bit tight, to the point of bind. I used a dremel disc to clear that up and used lithium grease on it. Perfect this way.
Brass can still get grungy
Reactions: NSANE530
I've gotten a chatter when dropping down into second or first when I'm still rolling forward. I think it's clutch chatter, honestly. Like the others stated above, I don't usually downshift into 1 or 2 until I'm nearly at a stop. I usually just pop into neutral from 2nd and let the clutch out. Then, clutch in and down to 1st.
Discussion Starter · #12 ·
The brass bushings are not binding, if I watch my speed and be stern with my down shifts it seems to help.
1 - 13 of 13 Posts
