Transmission Broke | Victory Motorcycles: Motorcycle Forums
Transmission Broke
Discussion in 'Victory General Discussion' started by VitaliMagnum, Sep 27, 2020.
  1. VitaliMagnum
    VitaliMagnum Well-Known Member
    Jan 29, 2017
    242
    331
    Bunnell FL
    2017 Victory Magnum
    So I started out this morning and made it about 3 blocks and something broke in the transmission. It sounds like a rod knocking. Never made a sound before. Just a Big Bang. Rode it back home easy.
    Any thoughts ?
  2. jedi-mcfly
    jedi-mcfly Well-Known Member
    Sep 11, 2014
    9,306
    3,035
    Alberta
    2005 kingpin
    History?
    Did it complain at all or have symptoms before it called it quits?
  3. VitaliMagnum
    Jan 29, 2017
    242
    331
    Bunnell FL
    2017 Victory Magnum
    Never made a noise before but when we got ready to leave and I put it in gear it acted like it was between gears or something and didn’t want to move. I put it in neutral and back in first and it was fine. Got to fourth gear and started to slow for a speed zone and when I downshifted to third it went BANG ! This bike only has 8000 miles on it !
    • Informative Informative x 2
  4. Known1
    Known1 Well-Known Member
    Apr 30, 2012
    4,301
    1,379
    Cement Slab, MN
    2013 Cross Country Tour
    What does it sound like while idling in neutral now? What if you lean it way over side to side while idling in neutral?
  5. jedi-mcfly
    Sep 11, 2014
    9,306
    3,035
    Alberta
    2005 kingpin
    I will/would be interested in what went kaput... probably be safer to get a reworked mill from Rylan then remove - split - fix - reinstall your existing.
  6. Bikesofbrads
    Bikesofbrads Active Member
    May 16, 2020
    365
    243
    South eastern ohio
    2015 victory cct & 06 katana
    Unless has been abused/neglected prob is something simpler than a whole tranny. Good luck, hopefully that clip just popped off or something. Is lots of info here & every1 of us is rooting 4 ya
  7. VitaliMagnum
    Jan 29, 2017
    242
    331
    Bunnell FL
    2017 Victory Magnum
    Don't know yet but I'll try it and see.
  8. VitaliMagnum
    Jan 29, 2017
    242
    331
    Bunnell FL
    2017 Victory Magnum
    This bike only has 8400 miles on it. I ride it sporty but never abused and maintenance on time. It's never done a burn out or wheelie. I rode my Magnum a lot harder and never had an issue at 35,000. Probably just a 17 and workers knew their job was ending and didn't give a ****. I'm thinking I'll just trade it for something and eat the loss.
  9. VitaliMagnum
    Jan 29, 2017
    242
    331
    Bunnell FL
    2017 Victory Magnum
    I went out and started it up and made no noise at all as long as the clutch is pulled in. When I let the clutch out it sound like someone inside the trans with a hammer no matter how much I lean it either way.
  10. recumbentbob
    recumbentbob Well-Known Member
    Feb 9, 2014
    1,709
    418
    Newburgh, IN
    2014 Cross Country Tour
    Sounds like the torque compensater ito me.
  11. Bikesofbrads
    May 16, 2020
    365
    243
    South eastern ohio
    Yea doesn’t sound like it’s ka’put, is fixable for reasonable & if ya take that good of care of it than it’s deff ia keeper. Pop the cover off & have a look
  12. Chattanooga_Mark
    Dec 25, 2009
    4,061
    1,466
    Chattanooga
    2012 CCT, Wonderful in white
    That it's not making a chattering noise when you lean the bike over a bit at idle is excellent news. As others have suggested, it could be a relatively simple fix.
  13. VitaliMagnum
    Jan 29, 2017
    242
    331
    Bunnell FL
    2017 Victory Magnum
    I may not have stated it clearly but it does chatter when I lean it either direction. I’m gonna probably pull the cover and see what I can see.
  14. K1ll3m@LL
    [email protected] Well-Known Member
    Mar 6, 2015
    2,638
    789
    Lake County, FL.
    2011 Victory Cross Country
    Let us know what they offer you on trade in..... Somebody on here may buy it at that price and get it back on the road.
  15. Chattanooga_Mark
    Dec 25, 2009
    4,061
    1,466
    Chattanooga
    Ok, chattering at idle when leaned to the left sometimes means a C-Clip in the transmission has let go. “If” that’s the case, engine removal and spitting the engine cases is the only way to find and fix it. That $1,00 C-Clip costs thousands to R&R. If you could post a video with you straddling the bike at idle and leaning it over a bit that could confirm things somewhat.
    Rylan at The Vic Shop is one of the best with the transmission C-Clip scenario.
    “If” the C-Clip has let go, the bike is not rideable nor trade-in material. Again, if, the engine has to come out and be torn apart, reinstalling some of the stock 106”’ pieces is often replaced with big bore kits, cams etc etc.
