I had looked prior as well. After changing mine out to another speaker, stock size, I cannot see there is any way to make a 6.5 work. For mine, because of larger magnets, I had to cut the inside of the trunk to make it fit.I've looked all over the net to see what people have done to upgrading the speakers in the tour pak. None of them showed a 6.5 in the original pod area. Has anyone fit a 6.5 in the original location? What do you suggest?
Without modding trunk 6.5 will not fit.I had looked prior as well. After changing mine out to another speaker, stock size, I cannot see there is any way to make a 6.5 work. For mine, because of larger magnets, I had to cut the inside of the trunk to make it fit.
