I was wondering if anyone knows if they sell these washers with different load ratings? Also can these washers be purchased anywhere else other then Victory??
Well thank you so much for the fast reply. I am going to ask another question now. Where can they be purchased? Do you have a site? Link? Any and all information would be appreciated. Thank you againThe answer to both of your questions is "yes".
Well that was very helpful. Thank you!The washers are call "Belleville" washers. You can find them from a number of sources. I have no information regarding the "K" rating of the spring force that you need.
where is information so others that come here can find the washers and springThe washers are call "Belleville" washers. You can find them from a number of sources. I have no information regarding the "K" rating of the spring force that you need.
The Belleville washer is a spring; it's termed a disc spring. The "K" value is determined by how much force it takes to displace the spring; usually given in Lbs./In. or Nt/m . I have no idea where you could find the "K" values required for the torque compensator used in our motors. I'm just a mechanical engineer passing on a little knowledge; no experience with the torque compensator to share.where is information so others that come here can find the washers and spring
They may be one in the same; if it is expressed in lbs./in. or Nt./m, then it is the "K" factor. If it's units of measure are only lbs. or Nt., then it is quite likely a max. load capacity.The few Belleville dealers shows there specific size and Load ratings. What is the difference with K and Load ratings?
