1 - 6 of 6 Posts
I would recommend against squeezing something between the pinch bolts of the forks. Now, they cannot pinch as tightly as they would without it.
Bicycle Automotive tire Vehicle brake Bicycle part Rim
I'd find some clamps of the correct diameter, put them around the fork, and make them black...
Discussion Starter · #6 · (Edited)
The pinch bolts actually tighten up all the way before it touches my brackets. I had to install thin rubber washers to keep the brackets from being loose. It worked out perfectly!
On another note, I tried some of those clamps and they were too small. They measured 39.8 mm. The forks are 43mm. I tried to use a die Grinder to round them out and couldn't even get them close.
Thanks for looking out though!
1 - 6 of 6 Posts
