tire size question | Victory Motorcycles: Motorcycle Forums
tire size question
Discussion in 'Victory Gunner' started by bronze, Jun 4, 2015.
  1. bronze
    bronze Member
    May 21, 2014
    84
    9
    2012 Highball
    Hi all,
    Hopefully I didn't get a reply in the tech forum, hopefully someone here can help.
    Quick question. I am looking for some sticky performance tires for my Gunner - I have my eye on the Pirelli Night Dragons (if you know of a better performer, please let me know!) Handling and grip are more important to me than tire mileage.
    The Gunner's rear tire is 140/90. The PND's closest size is 150/80 on the rear.
    Would it be safe to get the 150/80's for the Gunner?
    Thanks a million!!
  2. Orthoman60
    Orthoman60 Member
    May 23, 2015
    54
    11
    2015 Gunner
    Sorry bronze, I don't know about tires. But if you can could you make a quick video so I could hear those bassani's? And I love to see your swing arm bag thanks.
  3. UIWMC
    UIWMC Active Member
    Apr 17, 2015
    408
    222
    Tennessee
    14 Vic XR8ball
    I used to run continental on my concours loved them not much for long mileage but great ability to hang the corners look up the sport attack another is Michelin sport series
  4. vision_nut
    Aug 15, 2011
    7,876
    747
    vision 08
    don't think they make sticky tires in bias ply. Sorry you can't run radials
  5. russellh575
    russellh575 New Member
    Jul 31, 2014
    17
    11
    Hobbs
    Gunner
    They should be radials unless I'm missing something and he has spoke wheels instead of the stock wheels
  6. Luciferiad
    Luciferiad Active Member
    Aug 7, 2014
    352
    158
    Twin Falls, Idaho
    2011 Crimson Cross Roads
    the 150/80 is a 1/2" shorter and a 1/2" wider. It'll make your speedo a hair optimistic, but the tire should be good.
  7. vision_nut
    Aug 15, 2011
    7,876
    747
    vision 08
    steel frame bikes do NOT run radials. You can run one on the "back" but thats it.
    You do not have enough power to run a sticky tire. If your leaning over to far smartin up and don't do it
  8. catwrench59
    catwrench59 Well-Known Member
    Dec 14, 2013
    1,778
    459
    Lacon
    2012 Victory Cross country tour
    I ran Pirelli Night Dragons on our Vegas good grip and a nice tire. Avon Cobras are supposed to have a lot of traction as well
  9. triumph900
    triumph900 Active Member
    Mar 1, 2013
    891
    199
    VA
    Triumph Bonneville T120
    With the very limited cornering clearance on the Gunner I wouldn't think sport rubber would be applicable or needed. I will agree that the stock tires aren't all that great, but I've never had any cornering grip issues. When the stock tires are done on my Gunner (or maybe before!), I'm thinking about Michelin Commanders.
  10. rodhotter
    rodhotter Well-Known Member
    Aug 5, 2013
    1,979
    258
    pennsylvania USA
    2013 victory hammer
    night dragon radials on my 13 hammer are great! if you could a pair of 18" wheels from another Vic would allow low profile radials. not sure about clearances but checking specs on Avon + other sites will tell. try to get similar OD + the section width, the widest part of tyre is key! i would think even non radial pirelli's would be an upgrade + generally one size + or - will work correctly, again check tyre manufacturers sites for important specs
  11. Bujee1
    Bujee1 Well-Known Member
    Jan 3, 2015
    5,650
    2,839
    SoCal
    2011 Cross Country, and 2016 Cross Country Tour
    I call BS.
    Bias belted tires have a squared tread surface where Radials are round, hence the name radial. Besides who ever heard of an H rated bias belted tire? H Rated tires are good up to 130 MPH.
  12. Bujee1
    Jan 3, 2015
    5,650
    2,839
    SoCal
    Here is a pic of a bias belt tire: image.jpeg
    And here is a pic of a radial tire:
  13. 53canuck
    53canuck Well-Known Member
    May 25, 2013
    1,952
    814
    Left Coast, Canada
    2011 KP
    http://www.victorymotorcycles.com/en-ca/2012/cruisers/hammer-s
    http://www.victorymotorcycles.com/en-ca/2012/cruisers/vegas-8-ball
    OP, lots of steel framed bikes come with radial tires from the manufacturer and many riders also change to radials when they wish. It all depends on what the manufacturer and you want out of a tire.
    Be aware though that tires are part of the bikes engineering process and changing may or may not be to your liking. Load makes a difference as does the flexibility of the bikes frame. Some here have had problems with high speed wobble while others have not. Others prefer one tire manufacturer over another. Due to the differences it would help to get input from someone who rides the same model of bike as well.
  14. rodhotter
    Aug 5, 2013
    1,979
    258
    pennsylvania USA
    2013 victory hammer
    bias tyres are like damper rod forks cheap + underperforming, you can put radials on most anything, wire wheels include!! pirelli night dragon's are great but wear faster a typical tradeoff, traction or wear
  15. catwrench59
    Dec 14, 2013
    1,778
    459
    Lacon
    You need to read up on tire construction. A bias ply tire can have a rounded surface just the same a radial. It has to do with the belt or lack there of in the carcass. A radial tire has a belted construction. Bias ply doesn't.
Similar Threads
  1. Jphillips
    6
    1,740
  2. vtxski
    10
    3,670
  3. Matt Cooley
    3
    2,874
  4. jimmi
    11
    7,488
  5. ZuluMike88
    1
    846
Loading...
17 crosscountry rear tire size
2011 victory cross country motorcycle tire sizes
2011 victory cross country rear tire size
2011 victory cross country tires
2011 victory hammer tire size
2013 victory cross country rear tire size
tire size for a victory vision 2013
victory cross country front wheel size
victory cross country tire size
victory cross coutry tour tire size
victory gunner back tire
victory vegas low profile rear tire
