1 - 8 of 8 Posts
Hey everyone, just checking if anyone else has trouble with the throttle sticking. Mine seems to only do it when temperature is above 90 and sunshine. Seems the grip is expanding in hot weather and binding up. It’s easy to turn back manually but does anyone have the diy quick fix or should I take it in ? Thanks in advance for any advice.
The grip is probably expanding enough to rub on the switch housing. Just loosen the housing and move it enough to give a little clearance. No cost easy fix.
Reactions: VitaliMagnum
Pull the end cap out a bit. They just push in, and if you bump it, you can cause it to bind.
Did you put the quarter turn throttle in? I know when I put mine in I had a problem with that so I took a grinder and just took a small amount off and it worked well could possibly do the same thing with the stock not sure though.
1 - 8 of 8 Posts
